The following will include some duplication of the responses below. A BACKFIRE is a small explosion of the flame at the torch tip which may be the result of several avoidable conditions. The most frequent cause is preignition of the gases. Some causes of backfiring are: 1. The gas is flowing out too slowly and the pressures are too low for the size tip (orifice) used. The gases are therefore burning faster (flame propagation) than they can flow out of the tip. This trouble may be corrected by adjusting to a slightly higher pressure for both the oxygen and the acetylene. 2. The tip may become overheated from overuse, from operating in a hot corner, or from being too close to the weld. Cool the tip. 3. The inside of the tip may have carbon deposits or a hot metal particle may be lodged inside the orifice. These particles become overheated and act as ignitors. Correct this by cleaning the tip. Backfiring happens rarely but could occur when the inner cone of the flame is submerged in the puddle. This comes from one of the college textbooks "Modern Welding" by Althouse, Turnquist, Bowditch, and Bowditch.
