Tool Talk Discussion Forum
2 cyl. Tachs Timing devices
Bob
01-23-2004 07:15:49
Gentlemen I see several different types of proximity tachs and timing devices for 2 cylinder engines available and need advice on the ones best suited for this at a reasonable cost. Thanks in advance�.
Dell (WA)
01-24-2004 13:33:24
 Re: 2 cyl. Tachs Timing devices in reply to Bob, 01-23-2004 07:15:49
You can get watch battery operated LCD multi-cylinder selectable tachometers that just wrap an antenna like sensor wire around any sparkie wire $20 JCWhitney, etc..... ...Dell
i r baboon
01-23-2004 19:23:50
check any rotax engine supplier, be blessed
Bguy
01-23-2004 08:51:32
Bob, I have found that a hand held mechanical tach is real handy on these old two cylinders. You don't have to worry about whether it's 6 or 12 volt and you can check the crank speed and PTO speed easily. I use mine a lot checking idle and WOT speed.
buickanddeere
01-23-2004 07:47:56
The lettered and 1st numbered gas/all-fuel distributers ran at crank speed. A four cylinder tach works fine.
