Tool Talk Discussion Forum
What the pluck? Mating a shaft to a disc
Michael In PA
01-22-2004 16:25:14
I am constructing a chicken plucker, and it spins a 24" disc in the base of a barrel. To spin the disc, I have a keyed shaft with a pulley at one end (to be driven by a v-belt), and at the other end I need to mate the disc. Welding is not an option, as the disc is polyethelene. I have been searching McMaster and MSC for a flange or hub that will attach to a keyed shaft and have bolt holes for securing the disc, but I can't find anything under Power Transmission. Can anyone confirm that such a coupler exists, and educate me on its name?
Michael In PA
01-24-2004 10:10:58
 Re: What the pluck? Mating a shaft to a disc in reply to Michael In PA, 01-22-2004 16:25:14
Thanks to everyone for your ideas! Welding a disc to a collar sounds like a good first approach.
T_Bone
01-23-2004 15:01:47
Hi Michael,
You can also use a shaft lock collar with a circle cut SS disc on both sides. Weld one SS disc to the lock collar, install the plastic, then another SS disc, then bolt the sandwich.
I would let the shaft protrude thru the plucker disc and ride on/in another bearing collar attached to the bottom.
This would keep the disc from becoming out of balance when the chicken hits the...
T_Bone
Slowpoke
01-22-2004 22:40:44
You could use a split taper bushing with the id to match your shaft, and a solid V belt pulley that matches the bushing. The bushing is slipped on the shaft, taper end out and the pulley is placed on the taper. There must be matching holes (3) in your disk so when the screws are tightened from the disk side they draw the pulley on the taper locking it to the shaft along with the disk. You'll need to use a single very large washer under the 3 bolts to hold the poly disk secure.
Check catalogs to find which pulley models and matching bushings are lowest cost.
Just curious, did the design appear in "Farm Show" magazine?
wdTom
01-24-2004 18:42:11
 Re: Re: What the pluck? Mating a shaft to a disc in reply to Slowpoke, 01-22-2004 22:40:44
Split taper is the way to go. If there isn't too much torque involved you don't even need a key. I would also use the largest diameter solid Browning V belt pully as a flange if you need more support for the disc. Browning makes their V belt pullies solid up to about 6 in. in dia. with a nice machined finish. Not only does a split taper hold good, it is easy to remove too.
Slowpoke
01-22-2004 22:59:12
Or on second thought, you could use a set screw coupling that fits the shaft, and weld a steel disk of appropriate diameter to the end of it. Then fasten the poly disk to that. Maybe two couplings welded end to end would hold on the shaft better. Lots cheaper than a split taper bushing set, but probably not as sturdy.
TimV
01-22-2004 19:07:42
Michael: Another option would be to have one made--any decent machine shop could turn you one out of round stock, broach a keyway, and pop in 3 or 4 mounting holes. Depending on the shop, you might be able to slip it in as a "government project" and get out of it reasonably cheaply.
Burlgoat
01-22-2004 18:23:11
Michael,
you can use 1/2 of a love joy coupling for the hook-up that you are doing.Go to an air conditioning/refridgatin supply house they will have it or will order it for you.
You will need to know the shaft diameter.Good Luck
DaveCA
01-22-2004 18:18:28
Yes thewre are such things. Try a pump shop, hydraulics shop or industrial bearing supply.
