Tool Talk Discussion Forum
Welding aluminum with Century wire welder
Shane
01-22-2004 09:15:13
We have a Century wire welder and I was just curious as to what you have to do to weld aluminum. I obviously know you have to use a different wire but is there anything else? And do you use argon or does the wire have its own shield like the mild steel wire I use now?
R. Obregon
01-24-2004 18:22:46
 Re: Welding aluminum with Century wire welder in reply to Shane, 01-22-2004 09:15:13
Check out wirepropellant.com
Shane
01-23-2004 09:18:57
Thanks everybody, was just curious about using this welder. A buddy of mine has a really nice Miller that he can weld aluminum with but that whole setup was salty. Was just thinking!!
T_Bone
01-23-2004 14:50:44
 Re: Re: Welding aluminum with Century wire welder in reply to Shane, 01-23-2004 09:18:57
Hi shane,
Depends on how much AL welding you want to do, a acet/oxy torch works very well for welding AL. With practice gas welding can be made to look just like a Tig weld by using small tips and just the correct heat and at a lower cost.
T_Bone
Buck
01-22-2004 17:48:00
You also need U grooved drive rolls. V grooved rolls cut the wire, serrated rolls will cause little bits of aluminum to travel down the liner.
clint
01-22-2004 17:30:23
You will need a new liner,preferably one made specificaly for alluminum. I can't remember the material their made of. Lincoln sells them for their welders. I don't know if there available through century. You will have to use argon gas. You will also have to use 5356. 4043 won't feed at all. Your gun and lead will have to be as straight as possible. any kinks or bends and it will birds nest on you at the feed rollers. If everything is set up perfect it will work marginal at best.
John in MA
01-22-2004 10:22:19
You need the wire, probably a gun liner and tips, regulator, and gas. Most little welders aren't great with aluminum.
Bernie in MA
01-22-2004 16:39:03
 Re: Re: Welding aluminum with Century wire welder in reply to John in MA, 01-22-2004 10:22:19
Unless you use harder wire, like 5356, it doesn't push very good. A spool gun is a lot better but expensive.
John where abouts in MA are you? I'm north of Quabbin reservoir
John in MA
01-22-2004 17:06:05
 Re: Re: Re: Welding aluminum with Century wire wel in reply to Bernie in MA, 01-22-2004 16:39:03
I'm a little northeast of Boston, on the coast.
