Tool Talk Discussion Forum
Generator Starter - Moonlite, you around ?
Chuck - Up and
01-21-2004 15:48:46
On 18Jan04 Moonlite said - Had a lincoln welder withOnan air cooled 2 cylinder without a starter motor. It used the welding windings for starter from 24 volts from 2 12 volt batteried. Had a worker who had a lot of polarity problems. he jumped start it wrong and welder ran backwards blew oil out air intake but i just thought it had a busted piston. Tore into engine and found all ok.
Your post was referenced from - Yahoo homeshopprojects I have an old - '50s - Miller gen/arc that's rope pull. It's a bear to start !
I was planning to add a motorcycle starter but your idea sounds a lot simpler.
Can you give me more details on how it's done the right way ?
Thanx, Chuck U&R
