Tool Talk Discussion Forum
Welding a tractor manifold
Joe
01-21-2004 07:05:16
Hi,
I have a small 3/4" crack on my d17 manifold and wanted to know if I could weld the crack while still on the tractor, or should I remove it and weld the crack then place it back on. I was trying to conserve on putting a new gasket on and down time do you guys see a problem with that. What type of arc welding rod should I use. Thanks in advance.
Chris
01-24-2004 10:09:03
 Re: Welding a tractor manifold in reply to Joe, 01-21-2004 07:05:16
Joe, There is a guy on Ebay that sells new Vinson Manifolds(USA Made) for your D-17 for just over $100, gaskets and shipping included! They are great quality , superior to OEM from what I can see on mine. Welding cracks is a bandade at best. Money well spent in my book!
ShepFL
01-22-2004 07:44:55
I tried to weld cracked AC D10 manifold by welding a small stringer bead, cool, add another bead. Had poor luck. While trying to clean up the area I found more bad spots.
I ended up running my tractor to get the manifold hot and then I brazed it. While brazing make sure to cover the fuel lines - don't ask :) Now that the repair is done I have found that after running the tractor it has developed a hairline crack along the edge of the repair. I assume due to metal fatigue and the extra heat from the repair.
IMHO, repairing exhaust manifolds is a temporary fix at best. Currently trying to locate another manifold and hoping this one holds until late spring. Best of luck.
Rod (NH)
01-22-2004 13:26:53
 Re: Re: Welding a tractor manifold in reply to ShepFL, 01-22-2004 07:44:55
Hi Shep,
Here's a direct link to George's cast iron manifold repair. It's not just fixing a crack. It's a major rebuild of something most would throw in the dump thinking repair was hopeless. I am suitably impressed. I am going to try his method on something simple (like just a crack) when the weather gets warm this spring.
Rod
george md
01-22-2004 11:24:34
Shep,
Take a look at the web site and the links that
I posted below and see if you think the repair on the manifolds is a temporary repair. Success comes when you throw out the arc rod
and use acet torch and cast iron instick form.
george
Dell (WA)
01-22-2004 06:45:47
Joe..... ...welding castiron exhaust manifolds is tricky at best. Biggest problem is the castiron is porous and it assorbs carbon from the exhaust gasses, contaminating it and makes for extreamly difficult stickweld. Brazing is usually more successful (use lotts of fluxx) for castiron BUT the melting tempature of brass is close to the HOT exhaust gas tempature and often times "BLOWS-OUT". Always drill a "crack-stop" before you start any welding..... ....Dell
Wayne
01-21-2004 19:03:38
I've always had better luck brazing cracks in thin parts like manifolds, etc than in trying to weld them. True it may be brass colored rather than cast colored when your through, but it's a whole lot easier, and in an application like that, just as good. Either way I'd take it off the engine, and like one post said make sure the faces are true before bolting it back on. I've never had one mess up so much that I couldn't take a course file and straighten them back out without alot of trouble. Just lay it flat across at least two of the faces and work from one end to the other. Usually the gaskets are foergiving enough they don't have to be absolutely perfect anyway. Just my .02
george md
01-21-2004 11:37:39
Joe,
I would definitely take it off to weld , keeps the sparks and splatter from running down inside the manifold and into a cylinder with an open valve. Also would keep the arc weld away from the cast iron , weld it
with oxy/acet and cast iron rod . Look at this web site and the links to pictures, ,it will show you what can be done with
acetylene ad cast iron stick.
www.georgemillermachine.com
george
Craig
01-21-2004 08:16:02
Cast iron is very hard to weld. since you are asking this question, i'm guessing you've never welded cast iron before. I would strongly recommend that you remove the manifold and take it to a welding shop to make sure the job is done right. a gasket is much cheaper than a new manifold if you crack the old one. Before cast iron is welded teh entire part must be heated very hot. after welding, it must be cooled very slowly. the heating and cooling is often done in an oven. the cooling can also be done by burying the part in hot sand and then letting it sit. It would be pretty much impossible to do this without removing the manifold
jdguy
01-21-2004 17:53:10
 Re: Re: Welding a tractor manifold in reply to Craig, 01-21-2004 08:16:02
joe, take it off, get it welded, then take it to a machine shop and have it planed before putting it back on.
