Tool Talk Discussion Forum
T-Bone or others....Cast welding ??
Greywolf
01-21-2004 04:23:33
In the past I have had good success using a nickel rod for small minor cast welding jobs.
I recently got a few "cast" rods. Without preheating, they produce an immediate crack. The process I can understand.
In desperation one day, I grabbed the 110V wire feed with flux core .035 wire. Welded up well, with no cracking. These weren't critcal welds. Well kind of, I added a reinforcement band around the discharge helmet on the combine unloading auger. It held up all fall without any failure.
I have a couple cast welding projects I need to attempt, nothing to lose to try to fix first. Cracked exhaust manifold on a 504CI diesel, cast casing on water transfer pump.
Why the difference between the 2????? Is it because of the lower, concentrated arc on the wire feed that eliminates the cracking?
Did I just get lucky?? Or is something else at play with the .035 flux core?
Thank you for the replies.
Remove 123 for valid email.
T_Bone
01-22-2004 09:17:49
 Re: T-Bone or others....Cast welding ?? in reply to Greywolf, 01-21-2004 04:23:33
Hi GreyWolf,
Not a real good time for me to explain (pain) but it may be that the silicon in flux cored was more suitable to the type of cast you were welding.
I will try and write something up latter.
T_Bone
Greywolf
01-22-2004 09:48:19
 Re: Re: T-Bone or others....Cast welding ?? in reply to T_Bone, 01-22-2004 09:17:49
Thank you T-Bone
T_Bone
01-23-2004 21:48:59
 Re: Re: Re: T-Bone or others....Cast welding ?? in reply to Greywolf, 01-22-2004 09:48:19
Hi Greywolf,
Grey castiron contains a high silicon content and when heated to past critical temperature of approx 1450F the carbon starts to seperate in the form of graphite. This makes the cast very brittle and why we need to control preheating and posting heating as well control interpass temperatures while welding too control cracking.
By using the nickle electrodes, maybe with a slightly heavy bead without post and prheating, allows the weld zone to shrink too fast thus cracks.
On the other hand using the Mig innershield (flux cored) that contains a high silicon content was probabbly applied in a smaller bead or total heat I should say thus stayed well below the castiron critical temp.
The surafce of castiron also contains many contaminates and if not completely clean free will cause the weld to have prosity, cause cracking and effect the cooling rate that once again causes cracking.
So what am I saying? Yes you got lucky this time. I'm also doing quite a bit of guessing with the info given, ie; not seeing the exact weld procedure, metal type and filler metal, precleaning, joint prep, etc.
When welding castiron, there are rules to follow while welding no matter what the process used. Why? Castiron has a very loose grain structure when comparred with other carbon metals. Castiron will pick-up alot of contaminates easy and cool at a extreme temperature rate than the filler metal. I would compare welding castiron to that of welding Aluminum as they both require extensive precleaning and innerpass cleaning.
On common low carbon steel that has a tight grain structure, the HAZ (heat affectd zone) is not affected like castiron as both the filler metal and the base metal cools at approx the same rate so cracking is very rare. However failure to preclean can also cause weld cracking in mild steel.
T_Bone
cannonball
01-22-2004 08:10:55
i broke a jd manifold off right below where th clamp held the muffler on...set it back on tacked it in 4 places, cranked it up and welded it up using ss rods using a lincoln dc gas machine ..almost 2 years ago have new manifold but it is still in box....have nice day may god bless
Greywolf
01-22-2004 09:11:59
 Re: Re: T-Bone or others....Cast welding ?? in reply to cannonball, 01-22-2004 08:10:55
I too have rewelded the "stub" back on a manifold with nickel rod and it's still holding tight.
My main question is why the flux core didn't experience the cracking without preheat like the cast rod did.
I know I won't be getting the cast rods anymore, will go back to nickel. Unless the flux core works again. Time will tell.
John in MA
01-21-2004 17:44:36
I've done a lot of cast iron welding with an arc welder running 99% nickel rods. No preheating, but you have to peen as it cools.
george md
01-21-2004 12:31:03
Greywolf,
I've had very little real success with arc weld on cast iron , but great success with oxy/acetylene torch and cast iron rod especially
on manifolds. Look at this web site and the links to the pictures .
www.georgemillermachine.com
george
