Tool Talk Discussion Forum
Clamps
Cooker.308
01-21-2004 03:52:21
Are there special pliars,or what does a man use to get those band type hose clamps off? Working on a V.W. Jetta ,she is full of them.
Slowpoke
01-21-2004 11:08:41
 Re: Clamps in reply to Cooker.308, 01-21-2004 03:52:21
Some are just cut off, I think some with the multiple holes may be reuseable. You need a special tool to replace the bands, about $15.
jhill
01-21-2004 16:18:38
 Re: Re: Clamps in reply to Slowpoke, 01-21-2004 11:08:41
The clamps are called Oetiker clamps. The recommended way to remove them is by twisting the crimped area until it breaks and use a new one. The is a tool that is basically a pair of pincers that crimp the new ones. There should always be a gap in the crimped area. If not the clamp is too big.
Fern(Mi)
01-21-2004 05:41:02
Your local parts dealer should have these pliers. It is a good idea to continue useing those clamps as the continue to self tighten on healthy hoses. However I don't always practice what I preach.
Fern(Mi)
01-21-2004 17:03:00
 Re: Re: Clamps in reply to Fern(Mi), 01-21-2004 05:41:02
Hmm Boy, I stsnd corrected. I've got to get something to drive less than twenty years old.
Clamps made for one time squeesing? What wont they come up with next.
In The corner till I'm told to come out.
Mac
01-21-2004 18:43:48
 Re: Re: Re: Clamps in reply to Fern(Mi), 01-21-2004 17:03:00
I seen them clamps but the biggest i saw was for maybe a 1/2" or less hose. Thinks they used to use them on gas lines/filters when they only needed 7 pounds pressure, but new fuel injected cars have upward to 30 pounds of pressure.
Jhill
01-22-2004 20:02:16
 Re: Re: Re: Re: Clamps in reply to Mac, 01-21-2004 18:43:48
I have been a fuel system engineer for 22 yrs. You will separate the hose before the Oetiker clamp lets go. Current nylon hose lets go at 700-800 psi
