Tool Talk Discussion Forum
Using a welder to thaw pipes--110 volt??
Neal
01-20-2004 21:06:02
Occassionally (after extremely cold weather and when it starts to warm up)I have an underground water pipe that runs about 40 feet between buildings that will freeze up. I use a 230 volt welder set at around 40 amps to thaw out the pipes. It takes about one hour and ten minutes to get the water flowing. How would a 120 volt welder set at 40 amps work on thawing out the pipes? A 120 volt welder would be a whole lot lighter to load into the truck and then carry down the steps to the basement.
Also, what is the reason that the pipes freeze up when it warms up? It can be 10 below and the pipes will not freeze, but when it starts to warm up, the pipes will freeze. When we have a decent snow cover, I do not have the freeze up problem. I was given the reason for this and it made sense, however I am having a "senior moment" and can not recall the reason. I have told my tenants to let the water drip at a fast pace when the weather gets below zero, however they do not remeber to do it, and I have to get the welder hooked up.
john
01-21-2004 08:29:41
 Re: Using a welder to thaw pipes--110 volt?? in reply to Neal, 01-20-2004 21:06:02
"When we have a decent snow cover, I do not have the freeze up problem. I was given the reason for this and it made sense, however I am having a "senior moment" and can not recall the reason."
the reason for this is that as long as there is snow covering the ground, the soil tempertature will not go below freezing. The natural temperture of the soil a couple feet down is about 60 degrees. If the ground is exposed, the wind will cool the soil faster. if it is posible, next summer try adding another foot of soil above the pipe. the are of soil should be 10-15 feet wide for the entire length of the pipe. it will provide more insulation.
GK
01-21-2004 05:40:46
If at all possible DO Not clamp on the copper tubing. There is usually a brass or galvanized fitting somewhere to use for connections. As for lines freezing in the spring it is because the warmer weather drives the frost down. When you get your water line thawed out bend the float in the toilet and let it run until spring. It is just an automatic auction to turn a faucet off after using it.
Jimmy King
01-21-2004 05:19:53
My Dad had an old Miller 225 amp. 100% duty cycle at 225. in the late 1950's the water froze from my Granddad's house to the barn lot 75 yards Dad had to leave it hooked up wide open nearly all day before it thawed out. My BiL still uses the welder as Dad gave it to him when we bought a new one, and Dad bought it used at a sale.
John
01-21-2004 04:37:36
I just loaned my buzz box to a coworker,took 45 min to do 25 ft at 75amp ac.
Jake
01-20-2004 21:11:45
Was just wondering how you hook the welder up to thaw the pipes?
IowanJoe
01-20-2004 21:38:17
 Re: Re: Using a welder to thaw pipes--110 volt?? in reply to Jake, 01-20-2004 21:11:45
We used to thaw pipes out with a welder over a length of about 120'. The ground goes on a hydrant or the pipe in the cattle fountain, and the electrode side goes on the other end of the pipe that you think is froze. To reach that far we used the heaviest copper(overhead)wire we could find. A single strand of triplex would work also. If I remember right we had the welder set on about 80. It took some time for it to thaw out, but was easier if we did it just as soon as we found out it was frozen. One more point, get all the wires hooked up before you turn on the welder, if you have the welder running and the minute you touch the wire or ground clamp to the pipeline it just might burn a hole in the pipe, copper pipe for sure, it would be like trying to start an arch. I believe I would stay with the 220 amp welder, with a 110 welder you would be running it near full amps. Just a dumb note, one guy tryed to tell me it was not the heat that thawed it out it was the vibration. I know the triplex, when laying in the snow, will melt the snow, so I believe it is the heat.
Burt
01-21-2004 06:55:23
 Re: Re: Re: Using a welder to thaw pipes--110 volt in reply to IowanJoe, 01-20-2004 21:38:17
Heat is in a sense, fibration, because what is happening is the speeding up of the molucules and atoms involved. They thus bumb into each other causing vibration and spreading of the effect. To me they are the same thing.
Neal
01-21-2004 05:29:15
I also found that the pipes will thaw a whole lot quicker if you use sandpaper to clean the pipes up good in the area where you hook your clamps. For the wire, I used romex #12 and just wound all three wires together and bolted a small steel plate on one end to attach the welder to, and put a welder ground clamp on the other end to connect to the pipe. It makes for a simple hook up when needed. I made an adapter to plug the welder into a drier outlet in the basement.
Dave
01-20-2004 22:21:07
one winter years ago we had the water line between our house & barn freeze ....i had also heard the "vibration " story --well i can't tell you if it's vibration or heat , but i just left a double strand of barbed wire hooked to each end for about 3 weeks untill it warmed up ....i just turned the welder on every morning when i went past the shed (where the welder was) to the barn ....i think i used pretty high amperage -(prob'ly even Max.)but i do know it was about 250 YARDS , and it would thaw in about 10 minutes - so i lean towards the vibration concept - can't see how it could warm up that fast ?? (wires never seemed to get warm at all ??)
T_Bone
01-20-2004 22:48:24
 Re: Re: Re: Re: Using a welder to thaw pipes--110 in reply to Dave , 01-20-2004 22:21:07
Hi Neal,
You will need to watch that you don't exceed the amperage 100% duty cycle rating. You could burn up a machine by doing so.
Some machines have a thermal overload and some don't. If you have a overload and If you exceed the duty rating then the machine shuts off until the x-former cools.
T_Bone
goofus fr L.A.
01-20-2004 21:20:23
Neal, I use a drop cord with a metal bulb guard, put it on the frozen pipe and wrap it with something that won't burn easy, then let my mother n law watch till the water starts running.
goof
