Tool Talk Discussion Forum
TD340 Track Adjusting Wrench
Oldfarmboy Jim
01-20-2004 00:15:34
I'm looking for information and leads to the track adjusting wrench that came with the crawler's tool kit. What size was it, 1 7/8, 1 15/16 ??? Anyone know how to get one? Thanks ahead of time, Jim
rhudson
01-20-2004 06:52:59
 Re: TD340 Track Adjusting Wrench in reply to Oldfarmboy Jim, 01-20-2004 00:15:34
you probably want orginials, but the ones that came with my dozer were off the shelf open ended. one end had been cut off and the remainder was welded into a section of thick walled tubing to get the leverage you will need. you will need two to first break the jam nut away from the adjusting nut. i'll check for size next time i with the dozer. as a afterthought i remember the wrenches i had were not perfect, it was hard to get a good nut turn without repositioning the wrench. so maybe the orginial has some sort of curve to the wrench handle?
