Tool Talk Discussion Forum
Which to buy first
old
01-19-2004 08:28:46
I would like to add a few more tools to my shop but only have the money to buy one right now which would you guys get a porta power, a shop press 12ton or a pipe bender. I plan on all 3 but can only get one right now so which one????
JACK
01-20-2004 22:20:41
 Re: Which to buy first in reply to old, 01-19-2004 08:28:46
GET THE SHOP PRESS IF YOUR LOOKING FOR A 12TON CHECK OUT THE OTC STINGER. THE STINGER IS ALOT BETTER THAN THE ONE HARBORFREIGT AND MOST MAIL ORDER PLACES SELL ANOTHER THING NICE ABOUT THE STINGER IS THAT THE RETURN SPRINGS ARE CAPTIVE AND ABOVE THE PRESS THE CHEEPER PRESS HAVE THE SPRINGS NEXT TO THE JACK AND RIGHT IN FRONT OF YOUR FACE.
Vern-MI
01-19-2004 16:16:02
I would go with the hydraulic press first. I have a 12 ton press and if I were to buy one again I wouldn't get anything smaller than a 20 ton unit. Also buy the floor mounted unit rather than the bench mount. The added height allows much more flexibility when pressing on axle bearings and such. I even use it to press in new pick, axe and sledge hammer handles. I use two part epoxy on the handle and head and it acts like a lubricant when pressing the handle in and then as an adhesive to make the joint permanent.
Fern(Mi)
01-19-2004 09:57:32
Shop Press is handy straightening out those parts ya bent somewhere else.
Opps.
Mike M
01-19-2004 09:45:23
I would get the shop press first. You might get lucky at an auction or used tool jockey and find a old blackhawk press that uses a porta-power to power it. I found one then bought a very large 2-3 jaw OTC puller attachment that fits on the porta power.That hydraulic puller is sure the best.
T_Bone
01-19-2004 09:44:23
Hi Old,
I would buy the shop press as then when you get pipe bending dies, you can adapt them to the shop press.
T_Bone
Butcher
01-19-2004 09:37:30
Grizzly Industrial sells a 12 ton for $99. + $35. shipping.
www.grizzly.com
ShepFL
01-19-2004 09:07:43
Me, I would opt for the shop press. I find myself wishing I had one more often than not.
FWIW
CRUSADER
01-19-2004 08:47:04
Hey old,
I would go with the shop press first. Seems like a shop press is one of the most versatile pieces of equipment a person can have in a shop next to the air compressor and arc welder and cutting torch.
Jim
