welding is somewhat easy to do, but it takes plenty of practice. First off, you'll need plenty of scrap steel, Don't practice first off, on anything you'll want to keep. First off, you'll need a welding helmet and a chipping hammer is also a good idea, you can pick these up wherre ever you get the welding rod. the first obsticale you'll have is linine up the rod with the area of the steel you'll want to weld. it takes practice. but be patient. once you get that down, you'll wnat to try to keep the rod away from teh steel about 1/8 of an inch. this will stop the rod from sticking to the steel and will create the arc you'll need to welkd properly. when welding, its best to weld larger or thicker steels to thinner steels, once you begin, thsi should make a buit more sence. also, I try to aim the rod for the center of the two pieces of steel to be welded. depending on what I am doing of course. Welding can be a lot of fun, and very usefull, But it does take plenty of practice, so be patient and have fun learning. and here's a test for you, when you think you got the hang of it, take two pieces of steel, weld them together, allow them to cool, and then break them apart, if they come apart easily, then keep practicing, if you really have to werk at getting them apart, then you just might have the right technique. at anyrate, once they are apart, you'll be able to see, just how good of a welder you are, by examine the weld and the steel. good luck, and remember to keep it fun. if you have any other questions, please feel to email me direct Tom
