Tool Talk Discussion Forum
Welding dissimilar metals
Sean W
01-18-2004 22:22:16
Hello, I was going to get some exhaust flex hose, probably 304 Stainless Steel, and I wanted to weld it onto a regular carbon steel pipe. Thickness of the pipe is about 3/16"-1/4" maybe, and the flex hose is probably about 1/16"-1/8" thick. I had purchased some SS electrodes for the arc welder, and I am all set with it, but I wonder if it will bond good enough, or work at all? I have another option of getting galvinized steel flex hose, and I know I can weld that onto the pipe fairly easy with our MIG welder using .035" wire, and gas of the 75%-25% mixture. But the main questions is can I weld the SS flex hos to the carbon pipe, with the SS electrode?
mehmet
03-24-2005 01:10:15
 Re: Welding dissimilar metals in reply to Sean W, 01-18-2004 22:22:16
flexible exhaust hose type which is more resitance against to temperature and several conditio�ns is chrom nickel plated 304 or 316 quality. Nickel plated steel is cheaper but not as strong as chrom nickel one.
T_Bone
01-19-2004 04:27:05
Hi Sean,
You will need to use 309 SS electrodes for welding dissimular metals of SS to mild steel. 309 works well and has been around for many moons.
Hold most of the heat on the thicker part washing the puddle onto the thinner piece. Hold a tight arc and you might want to practice on some scrap as 309 has a funny looking molten puddle using some shades/color of welding lens, meaning hard to tell the molten puddle from the slag.
It doesn't matter what process you use as it's the filler metal composistion that counts.
T_Bone
george md
01-18-2004 23:19:05
Sean, I don't think the flex pipe will stand up to the arc weld , the material in the pipe is very thin. You might try some brazing rod with either yellow or blue flux coating . Probably the best way is hot spray torch with a high nickel material like eutectic # 10680, it will flow well to both materials. If you are going to use it for exhaust ,don't bother to get the galvanized flex , it is very short lived. The usual way to connect the two is with a band clamp . also you might be able to tig weld with stainless rod , keep the heat on the heavy section .
george
Sean W
01-19-2004 10:45:11
 Re: Re: Welding dissimilar metals in reply to george md, 01-18-2004 23:19:05
I'm sorry I should have specified what my intetions were. But I am not going to use it for exhaust, but I am going to use it for my grain vac for a suction hose conveying corn and soybeans. The companies of the grain vacs use tis flex hose and I seen three different styles of flex hose. 1.SS, packed with a smooth liner inside. 2.SS, packed and no liner. 3.Galvanized steel, and packed with no liner either. So I think I can use what I was looking at, at the truck store. But I am going to do so more research on it before I weld.
