Tool Talk Discussion Forum
brakes
Mike
01-18-2004 08:05:35
I have a ford 1953 golden jubilee and I put new brake pads on it last spring. The brakes worked fine all summer and into the fall then all of sudden the right tire would just lock up on me. It dosn't lock up when I go in reverse. I tore the brakes back apart thinking a spring was broke but everything looks fine. Could the spring be just weak or could there be a different problem.I was wondering before I start buying parts.
thank you for any information. Mike in WNY
JED
01-20-2004 22:40:27
 Re: brakes in reply to Mike, 01-18-2004 08:05:35
SOUND LIKE A CRACKED SHOE OR LOOSE LINNING TO ME
Mac
01-18-2004 08:29:37
Did you replace the flex hose, hardware and use the proper lub. when you initially did the brake job.
Mike
01-18-2004 11:13:11
 Re: Re: brakes in reply to Mac, 01-18-2004 08:29:37
the brakes are mechanical
charlie
01-18-2004 12:39:54
 Re: Re: Re: brakes in reply to Mike, 01-18-2004 11:13:11
check and see if you have a leaking axle seal.just a bit of grease on the brake shoe will cause if to grab.good luck.
Harrison
01-18-2004 18:39:01
 Re: Re: Re: Re: brakes in reply to charlie, 01-18-2004 12:39:54
I agree with Charlie.Even a small axle seal leak or wheel cylinder leak will cause the brakes to grab.
goofus fr L.A.
01-19-2004 10:30:58
 Re: Re: Re: Re: Re: brakes in reply to Harrison, 01-18-2004 18:39:01
Its like Charlie said in the begining, but later on the brakes won't hold at all. You have got to pull the axle, then cut the retainer sleeve, and remove or cut the beering race off then install a new seal. The good old boys and red necks don't do this, when they refurbish one for resale, because of the cost and labor involved. goofus
If you enjoyed this post, Help support this website by becoming a [Voluntary Subscriber] oln $8.00 just click on the link at the bottom of the page.
Yours truly, goofus fr LA (lower Al. down home)
