Tool Talk Discussion Forum
021 Stihl
John in IN
01-18-2004 07:17:46
This season my saw has been loosing power. I changed the plug and made sure the filter is clean. I always use stabil in my gas and have not had any trouble with my other saw or two cycle engines. So I don't think it is fuel related. Tryed adjusting the carb. didn't seem to change anything. Starts good its just when you put it to a log it looses power. Is it wore out? Have always used Stihl 2cycle oil. 11 years old. Thanks.
Larry e
01-18-2004 18:39:25
 Re: 021 Stihl in reply to John in IN, 01-18-2004 07:17:46
Louie Fuller,would you be the guy in LaJunta?
buckshot
01-18-2004 17:45:13
on my well worn o28super i have to take carb off about every year or so and give it a good cleaning turn your adj scews all the way in then back out 1 1/4 turn as a starting point and adj from there works for me
buckshot
01-18-2004 17:42:52
bob
01-18-2004 17:16:20
If not your muffler, carb may need rebuilt, if adjusting it makes no changes. If you used it an extreme amount, cylinder, rings, piston could be worn out.
Louis Fuller
01-18-2004 08:07:02
Clean out your sparkm arrestor screen and exaust ports in the cylinder reajust carb. should be ok hope this helps thanks Louis
stihltech
01-18-2004 18:12:00
 Re: Re: 021 Stihl in reply to Louis Fuller, 01-18-2004 08:07:02
Pick up saw by starter handle. Rope shuold hold saw up or come out very slowly. This tells you if the compressiom is OK.
Screen in the muffler first, then go after the fuel system. Use new parts, you are just wasting your time otherwise.
