Tool Talk Discussion Forum
Welding Rod Designation
Benj. J. Joe Br
01-17-2004 17:55:22
Hello Everyone, Could some one give me the numbers and letters(?)that identifies hard surfacing welding rod.
T_Bone
01-19-2004 04:13:35
 Re: Welding Rod Designation in reply to Benj. J. Joe Browning, 01-17-2004 17:55:22
Hi Benj,
You got me on this one. I looked around on the AWS website and didn't find any refference to hardface electrode standards. I thought that in the late 80's or so there was a standard made.
From looking at Lincoln's website there must not be a standard and there still using the mfg's discription for hardface electrodes.
Mfg's like it this way as then you can't compare electrodes from one mfg to the other.
T_Bone
01-19-2004 10:58:51
 Re: Re: Welding Rod Designation in reply to T_Bone, 01-19-2004 04:13:35
Hello T_Bone, That's the same thing I found. It is little surprising to me that no standard designation has been establish.
Guess I'll have to go to the various welding suppliers and get their list.
Thanks, Joe
T_Bone
01-19-2004 11:18:37
 Re: Re: Re: Welding Rod Designation in reply to Benj. J. Joe Browning, 01-19-2004 10:58:51
Hi Joe,
Click on the link below and goto Linclons website then click on consumables then hardface and it'll give you a list of all the electrodes they carry and explain how to use them.
T_Bone
01-19-2004 20:59:37
 Re: Re: Re: Re: Welding Rod Designation in reply to T_Bone, 01-19-2004 11:18:37
Hello T_Bone,
I was able to get a copy of a cross reference sheet put out by UTP Welding Technology. It appears to compare the various brands as they relate.
Thanks, Joe
old
01-17-2004 20:33:59
I have a box of it but not sure if I got the numbers right since it is all I could do to see it but I think it said H80 hard faceing
Wayne
01-17-2004 19:39:29
I've never actually seen a hard surfacing rod with a "standardized" number like your 7018 or 6011. In the case of normal rods the first 2 or 3 digits are your tensile strength in 1000psi (ie 7018 has a tensile strength of 70,000psi)... the next digit is for the position the rod was designed to be used(ie- multiposition, flat only, etc...)and the final digit indicates the properties in the flux coating and wether it's an AC or DC rod. Most if not all hard surfacing rods are gonna fall outside these normal parameters. In the suppliers catalogs they are usually given a name such as Hardaloy, Welco 240 Ni-mang or something similar. The rod itself will usually be marked simply with the name and alloy used, like the Welco rod mentioned above, or simply with the designation for the alloy by itself, if they are marked at all. Like I said I haven't seen and don't know what all the suppliersd out there do, but this is what I've seen in my experience. Hope it helps.
