Tool Talk Discussion Forum
Dual moving tables on jointer
Shane
01-17-2004 07:19:07
I just bought a 6" jointer and it has no manual with it. What is the purpose of both the infeed and outfeed table being moveable. All the other jointers I have seen had just the infeed moveable. I would think that you would want the outfeed table to be at the same height as the cutterhead, as it is cut it would then ride on the outfeed table. If you lower the outfeed wouldn't it make your cut out of whack? Thanks for any help. Shane
DaveInMI
01-18-2004 04:08:35
 Re: Dual moving tables on jointer in reply to Shane, 01-17-2004 07:19:07
It will cut a curve instead of a straight edge if the outfeed table isn't adjusted right.
DH in Carolina
01-17-2004 12:18:10
The reason both front and back tables will move is if you want to use a set of cutters to cut molding with and can control the depth of cut. Also as was stated to be able to use cutters that were sharpened and become shorter. A knife setting gauge should be used to make sure all cutters are the same .
VaTom
01-17-2004 11:46:05
Hi Shane,
The outfeed table is rarely moved. Usually, knives are set from the outfeed table (not quite the same height- a little lower), wherever it's set. Probably the only time you'd want to move the table is if you replace very short many-times-ground knives with a new set. Adjustable outfeed tables come on the better jointers.
Don't forget to check that both infeed and outfeed are in the same plane. If not, you'll have to adjust it. Grabbing the jointer by the tables to move it is common, and often necessitates realignment.
My considerably larger jointer also has rack and pinion gearing to move both tables away from the cutterhead. Now that's something REALLY unusual.
Watch your fingers!
Paul Janke
01-17-2004 11:11:48
Is it to allow adjusting after sharpening blades which are then shorter?
