Tool Talk Discussion Forum
Plasma Cutter
Jimmy
01-16-2004 13:28:10
Could someone explain what a plasma cutter is and
exactly how it works. I know it's for cutting
metal, but how does it do it? Do you use bottled
gas with it or a compressor? Thanks.
Rod (NH)
01-16-2004 16:00:54
 Re: Plasma Cutter in reply to Jimmy, 01-16-2004 13:28:10
Hi Jimmy,
It's hard to beat a plasma cutter for thin materials (say thin gage to 1/4"). It gets increasingly expensive over 1/4" - perhaps prohibitively so unless you do an awful lot of work up in that area. For most farm or home type work, limit plasma to about 1/4" and keep oxy/acet or oxy/propane for the thicker stock. That's the most cost-effective plan in my opinion.
Here's a good technical description and history of the process itself. The unit I have uses compressed air from my shop compressor.
third party image Rod
T_Bone
01-16-2004 19:39:48
 Re: Re: Plasma Cutter in reply to Rod (NH), 01-16-2004 16:00:54
Hi rod,
another great website you've found. I've been looking around the net for awhile but never find the quality websites that you seam to find.
T_Bone
Ben in KY
01-16-2004 14:50:31
No flamable gas is used. The Plasma cutter either has an air compressor built in or uses air from an external compressor.
Jimmy
01-16-2004 19:26:15
 Re: Re: Plasma Cutter in reply to Ben in KY, 01-16-2004 14:50:31
Thanks for the help and answers guys.
