Stalling Farmall C
Scott Gates
08-09-2000 19:47:26
I have a Farmall C it has been running fine for the year that I have owned it. I just put new plugs, wires, dis cap, points, condensor, rotor, changed the oil all about 3 months ago. The tractor ran fine for 3 months working with a back blade, and york rake. I just started doing some brush cutting and after about 20 min the tractor will start to stall out. It will start right back up but as it gets warmer it starts stalling sooner.
Hope someone can help. Thanks Scott.
H MN
08-09-2000 20:36:18
 Re: Stalling Farmall C in reply to Scott Gates, 08-09-2000 19:47:26
Scott: You said that as it gets warmer it stalls sooner? Temperature related problem? Maybe the coil it getting hotter and breaking down somewhat and causing the problem. Got another coil like that one so you can swap'em fer a spell? If its plugged gas supply, can pulling the choke out some extend the runnung time? Just a couple suggestions..good luck.. harvey H MN
..one more time.
08-09-2000 21:18:02
 Re: Re: Stalling Farmall C in reply to H MN, 08-09-2000 20:36:18
....I mentioned coil because I did not see that on your list of items you replaced. ....and I wanted to mention that there is a Farmall forum where ya might get better responce rather than this tool forum. harvey
H MN
08-09-2000 20:36:09
Burrhead
08-09-2000 20:13:26
It sounds like trash or rust has built up in the fuel line or strainer. Try cleaning the strainer that's in the top of the sediment glass bowl assembly 1st.
Then if that does'nt do it take the fuel line off at the carb and blow the trash back out of the line with air pressure..
