Tool Talk Discussion Forum
Ford 460 Bellhousing problem
Jeremy Brault
01-15-2004 18:01:25
I was wondering if the bellhousings on a 400 Ford are the same as the ones on a 460 Ford. I have a problem where the pressure plate hits the bellhousing. I had a 400, and now have a 460. Any help would be awesome
Thanks Jeremy
Chris Brown
01-16-2004 04:48:43
 Re: Ford 460 Bellhousing problem in reply to Jeremy Brault, 01-15-2004 18:01:25
Yes a 400 bellhousing will fit a 460. You might have a heavy truck flywheel,like off a 370,they are thicker and would put the pressure plate closer to the transmission.
Jon H
01-15-2004 18:26:43
Should work. I repowered a 74 IH with a 75 model 460 using a cast iron 400 bellhousing I used a 390 flywheel and 11 inch clutch. The only modification was to move the flywheel ring gear forward to the front of the flywheel to engage the 460 starter. I had no pressure plate to bellhousing interference with a 11 inch clutch. Yours might be a bigger clutch or different style pressure plate.
Bundy
01-15-2004 19:52:34
 Re: Re: Ford 460 Bellhousing problem in reply to Jon H, 01-15-2004 18:26:43
just was looking for another engine for my 350 that has a 400. The junk yard manual says that the 460 will fit no problem.
