Tool Talk Discussion Forum
need ideas
old
01-15-2004 16:49:39
Years ago I took an old semi grain bed trailer and cut the wheels off and added a roof to store hay in, square bales worked good. But now I bale loarge rounds, how can I make it easy to get the rounds out of it with out brakeing my back and or spending an arm and a leg to make a converer system. Any ideas????? ??
i r baboon
01-16-2004 17:15:36
 Re: need ideas in reply to old, 01-15-2004 16:49:39
young, u mite try the old roofer trick, put a pallet under each one, pull pallet out w/ hook & chain. many site give u freee pallets. be b lessed
Chris Brown
01-16-2004 05:05:18
Why not use a couple ropes and a 4x4. Tie the 4x4
about 3 feet off the floor in the end of the trailer with baling string and put a rope on each end extending out of the trailer on both sides then push the bales in till they bottom out against the 4x4,that way you can pull them out with the tractor via the ropes.
. You might want to tie the 4x4 to the first bale so it does'nt fall down.
T_Bone
01-16-2004 02:10:04
Hi Old,
I was thinking of something on the windlass spool idea as it sounded like you wanted to keep it simple.
By using a rope with a graplin hook or bar(s) just hold a double rap around the windlass spool for outward motion.
For inward motion add a snatch block up high on the far end and again double rap the windlass spool.
Two seperate ropes to make it a fast simple to hook up.
I don't know how hard it would be to drive a pipe thru the center of each roll. Maybe a spreader bar with a clevis for each roll as that might pull best. That way you would just have to attach the clevis to the rope, rap around the windlass spool for either in or out. Then remove the pipe before you feed.
You want something more automated? I specialized in automatic controls for HVAC and with those controls you can control just about anything for a reasonable price.
T_Bone
