Tool Talk Discussion Forum
ThriftySpot - spot welder
Gene Sanderson
01-15-2004 16:30:48
Has anyone heard of a "Thrifty Spot" spot welder by Chapman? I purchased it at auction and would like to get some info on it. The gun is model CA-21 and the power pack is model CA23. It appears to be a quality made machine but I would like to read some instructions before trying it out. Hope someone knows something about it or knows where I can go to find out. Thanx, Gene
T_Bone
01-16-2004 02:38:43
 Re: ThriftySpot - spot welder in reply to Gene Sanderson, 01-15-2004 16:30:48
Hi Gene,
We had a Chapperel? Champion? pin spotter for installing duct work insulation pins back in the mid 70's.
The gun had a round magnetic head for the pins to stick too, then you put the pins thru the insulation, pulled the trigger, it then fuesed welded the pins to the sheet metal.
The pins had about a 1-1/4" round head with a 5/8" or 1-1/8" pin length x 3/32" pin diameter depending if your were installing 1/2" or 1" liner.
Sound like what you have?
T_Bone
