Tool Talk Discussion Forum
Plasma Cutter hookup
Steve
01-15-2004 07:43:46
Can a plasma cutter and air compressor be used on the same 220V circuit? The cutter will be using the air from the compressor, so they both will be running at the same time. I know the draw for the compressor, I don't know he amp requirements for a small plasma cutter.
Farmered
01-16-2004 04:28:59
 Re: Plasma Cutter hookup in reply to Steve, 01-15-2004 07:43:46
Anyone who can afford a plasma cutter can afford to do it right. Spring for another breaker, you'll be glad you did. Ed
Alvin n Ms.
01-15-2004 07:50:12
I will bet two pints of diesel, that it will throw a breaker. alvinnms
Benj. J. Joe Browning
01-15-2004 17:49:26
 Re: Re: Plasma Cutter hookup in reply to Alvin n Ms., 01-15-2004 07:50:12
I'll see your two pints and raise you another three. It will trip the breaker.
john
01-15-2004 12:44:31
I'll take that bet...
I used to run both on the same breaker...but was careful and watched my compressor pressure... when I got down close to the restart pressure I wouldn't start a cut... the start up current on the compressor would get me... the running current draw on the compressor and the running current on the cutter would never kick the 40 amp breaker.. that's with a 5hp motor on the compressor and a plasmark cutter cutting 3/16 material..
btw... I've since moved the plasma cutter/welder outlet to a seperate breaker to do away with the problem
john
