Tool Talk Discussion Forum
Welding Rods and Moisture Revisited
raytasch
01-14-2004 07:19:26
In the thread below we discussed that moisture in welding rods is not a good thing. Can one place the rod in an oven and 'bake' the moisture from the rod or should a rod that has been subjected to moisture be pitched?
thanks for all the knowledge exchanged here.
ray
tooly
01-14-2004 22:09:07
 Re: Welding Rods and Moisture Revisited in reply to raytasch, 01-14-2004 07:19:26
I have a shop at the farm which is only heated when I go to work there. In the winter I always keep a handfull of rods (7014) on rack on my barrel heater,that works wonders for making it easy to maintain a good arc. I am using a aircraft generator, driven by an old 52 Fordson Major tractor. Sure works for me!
Carl
01-16-2004 14:11:16
 Re: Re: Welding Rods and Moisture Revisited in reply to tooly, 01-14-2004 22:09:07
Ray, When your working with in an AWS D1-?? code there are lots of rules. Once a can of low hydrogen rod is opened, it has to be bake at 350 degrees for 24-hours, something like that. I could look it up if it's important to you. Working the majority of my life in marine construction in the Seattle area. You learn to work around moisture. I have poured water out of a can of 7018 grabed a rod and stuck it to the base metal, watched the water run off the rod and then welded with it just fine. Did not say it was X-ray quality. Carl
John S
01-14-2004 18:58:35
It is possible to dry them out. However its more of a pain then its worth. The have to be heated to the right temp for the right time or it does no good. If you get it wrong you either burn up the flux or you dont get the moister out
Tom
01-14-2004 11:49:56
Ray, as touched on below, you are going to have 99% of your moisture problems on the 7018, low hydrogen, rods. Other rods like the 7014 are not nearly as sensitive to moisture. If you are fairly new to welding, I sugest you try the 7014 rods. You will love them. I can do my best welding with them. A very experienced welder told me that the "BEST" rod is the one you can make the "BEST" weld with. In other words a 7014 bead laid down in an excellent manner is much better than a 7018 bead laid down in poor manner.
T_Bone
01-14-2004 07:41:50
Hi Ray,
Depends. Generally I would say yes they can. I've used electrodes that had water stains on the flux without any problems after being dried but then I've also thrown away electrodes with no water stains. If the electrode doesn't run well and it's not "you" causing the problems then it's time to toss them.
T_Bone
Alvin n Ms.
01-14-2004 13:10:26
 Re: Re: Welding Rods and Moisture Revisited in reply to T_Bone, 01-14-2004 07:41:50
Baking didn't help the ones I tried that had been subjected to humid conditions for several days. May would held for overnight exposure. I have a good friend that gave me several large boxes of rods, I use them for high strenth tie wires. alvinnms
