Tool Talk Discussion Forum
xl 76 homelite chainsaw
HENRY HEAD
01-11-2004 19:41:32
I HE HAD SOME OF THE PAINT COME OFF THE INSIDE OF THE FUEL TANK AND TURN INTO SYRUP AND PLUG UP THE CARB A NUMBER OF TIMES. WHAT COULD BE DOING THIS AND WARE DO I SET THE NEEDLE ON THE PUMP DIAPHRAM?
THANK YOU
treeboy
01-12-2004 16:44:45
 Re: xl 76 homelite chainsaw in reply to HENRY HEAD, 01-11-2004 19:41:32
old gas or gas with alcohol.... are you talking about the idle screw at the carb????? back it off till the chain stops but saw still runs... put some new gas in the tank with a little extra oil..
HENRY HEAD
01-12-2004 19:32:11
 Re: Re: xl 76 homelite chainsaw in reply to treeboy, 01-12-2004 16:44:45
THE NEEDLE VALVE INSIDE THE CARBURETOR THAT HOOKS TO THE DIAPHRAM WITH A ROCKING ARM.THE ARM CAN BE BENT TO ADJUST.
