Tool Talk Discussion Forum
homelite saw starts but no power
Lee Williams
01-10-2004 20:49:23
saw starts but has no power, also blows fuel out of the air filter. I was told it was the reed valves in the carb. but I just put a new carb. on it and nothing changed. what can I try now? Thanks Lee
FRED
01-12-2004 17:06:23
 Re: homelite saw starts but no power in reply to Lee Williams, 01-10-2004 20:49:23
CHECK THE FEUL TANK VENT IF IT IS PLUGED UP I CAN CAUSE THE SAW TORUN LIKE THAT
RusselAZ
01-11-2004 09:36:41
clean the exhaust ports on the cylinder and muffler
Mike in WI
01-11-2004 05:56:36
The reed valves are located inside the intake manifold of the crankcase housing.
Sounds like it is a broken or blocked reed if you have gas being blown back thru the carb.
What Homelite model?
Lee Williams
01-11-2004 10:01:52
 Re: Re: homelite saw starts but no power in reply to Mike in WI, 01-11-2004 05:56:36
It is A z3300.
Mike in WI
01-11-2004 10:40:35
 Re: Re: Re: homelite saw starts but no power in reply to Lee Williams, 01-11-2004 10:01:52
The older Homelites manufactured in Port Chester, NY were reed valve saws. The Az3300 model is a late 90's offshore design and may be piston ported (no reed plates).
Rings or timing may be bad as the cylinder pressure should not be blowing back out the carb.
Pappy
01-10-2004 23:20:48
I have one that has done that twice. Both times the exhaust screen was carboned up almost completely closed. I cleaned it and it runs like new again.
Terry H
01-15-2004 10:08:35
 Re: Re: homelite saw starts but no power in reply to Pappy, 01-10-2004 23:20:48
Same experience here!
Terry
