Roger V -- Don't buy a tap and die set until you've tried a machine-shop-production-grade tap. I prefer "spiral point" taps, which are designed to push the chip down the drilled hole ahead of the tap, for almost all work except for tapping shallow holes. With a spiral-point tap you just position the tap on the hole, line up the tap with the hole, and turn the tap into place . . . none of the infernal back-and-forth twisting to break the chips to keep them from jamming the tap into the hole. You can get good taps and dies from just about any "mill supply house" or Industrial Distributor (check the yellow pages under Tools, Cutting or Machine Shop Supplies) or from mail-order suppliers such as J&L Industrial, MSC, Travers Tool, or Rutland/Airgas. For most home or farm uses, you'll want a "ground thread, high-speed steel, spiral-point" tap, with either a "bright" or "steam oxide" finish. No need for Titanium Nitride or other coatings. This grade of tap is going to be more expensive than a hand-tap from a home center store, but I'll tell you the honest truth using an old cliche -- Try it; you'll like it! John
