Sandblasting hazards
Steve
08-08-2000 08:02:12
I am restoring an old car and thinking of buying a sandblaster. I live in a split level home with the garage on 1/2 the lower level. The house is separated from the garage with a fire door. My question is, would I be placing my family at risk by sandblasting in the garage(silica dust inhalation). If so, could I avoid this hazard by using different media?
Steve Hansen
08-08-2000 23:34:43
 Re: Sandblasting hazards in reply to Steve, 08-08-2000 08:02:12
Sand is a good media for axles and engine blocks but it can ruin sheet metal parts. In some cases the metal will distort. In other cases the metal will take a temper that makes it brittle and impossible to work with. It will also be susceptible to stress cracks. There are other media (walnut shells, plastic beads, etc) that are more suitable. A good book on automotive restorations should have a section on techniques and media for stripping metal. Don't cut corners. Their not making much of that old tin these days!
clooney
08-08-2000 15:18:46
Steve, if you sandblast in the garage you will make such a mess you will never do it again. That sand will keep comming out of the cracks & corners for the next 20 years. If you ever want to paint in that garage don't do it. Put a tarp down out side (as far from the house as possible) then get the wind to blow from one side then put on a GOOD respirator (I use a fresh air supply that feeds clean air through a hose & mask), a hood, leather gloves,& long sleeve shirt. Then have at it. I have found that the second & third time the sand is used it works the best.
AD
08-08-2000 10:20:18
Is there a connection to the house via central heat/air?? Is the door air tight seal. Do you have a way of having a negative air pressure in the garage. (That is to say an exaust fan that can be run when you are sand blasting). If you can keep a negative pressure in the garage it shouldn't allow any of the dust to go into the living quarters. If you have a heat/air connection you will need to seal it off or it will take the dust through your entire house.
Tyler(WA)
08-08-2000 10:10:39
I'm avoiding sand blasting for that same reason. Northern Hydraulic offers an attachment for a pressure washer that does "water/sand blasting."
No sand dust. I've been told it does a fine job.
