Tool Talk Discussion Forum
Homemade / welder, log splitter etc .
Sam
01-07-2004 11:22:35
I am wanting to homebuild a welder and a log splitter . I am looking to build a welder because I plan to start building my own woodstoves out of 1/4" steel . A log splitter will come in handy for me because I burn my wood in the winter . I have a 300 6cyl out of a 81 ford pick up . Anyone have any good ideas as to what homemade project I could use this for ?? thanks for all the help and any good ideas . Sam , [email protected]
John S.
01-08-2004 20:10:46
 Re: Homemade / welder, log splitter etc . in reply to Sam, 01-07-2004 11:22:35
I have plans to build a 100amp welder out of an gm delco starter. Real simple to.
RICK
01-09-2004 17:01:46
 Re: Re: Homemade / welder, log splitter etc . in reply to John S., 01-08-2004 20:10:46
i built my splitter about 20 yrs ago i bought the pump and valve at quality farm & fleet i have had probably 1/2 dozen engines on it over the years. and believe it or not right now i have a 3 hp engine off a go cart my splitter is 12 ft long i can unbolt the wedge and split 8 ft locust fence post from logs.the power is all in the pump.
Sam
01-10-2004 08:29:00
 Re: Re: Re: Homemade / welder, log splitter etc . in reply to RICK, 01-09-2004 17:01:46
the splitter you have is what Iam looking for . Could I get a copy of the plans for this ? Thanks, Sam
Benj. J. Joe Browning
01-08-2004 18:39:43
Hello Sam, For your information, my father in law build his own welder that used a tractors PTO to power the unit. He welded with it for years.
There are many good websites that might have information.
Try the following:
#1 The Yahoo group -Prints and Plans
#2 Metalworking.com
#3 Machine Builders Network
#4 Vintage Farm Plans-Metal Shop
You might also try the advanced search feature on Google.
Hope this Helps.
Joe
KURT
01-07-2004 16:10:33
My neighbor made his own log splitter, real nice and is road towable. 5" bore cylinder and has a 11HP engine. Probalby the nicest log splitter I have ever seen.
rhudson
01-07-2004 16:02:49
Try Surplus Center for surplus generators that could be used for welder, i think they also have a governor that you will need to regulate the engine. northern tool usually have splitter plans in a book rack in the stores. look up lincoln welding for some great project books with alkinds of splitters and other stuff. the books are pretty cheap (i think they were $14.95). i've seen the books resold on ebay for over $50.00 each. sure would like to have that L6 engine for my 82 f250. like most projects it helps if you have a source for cheap "scrap" steel and parts.
