Tool Talk Discussion Forum
Snow Plow on a Pickup Truck
Mike Thomasma
01-07-2004 08:33:25
During very cold weather (under 20 degrees), my Meyer plow barely moves.
Sometimes it acts as if it's "frozen" and I have to pull into a heated garage to free it up.
I've had the fluid changed and seal kit installed.
Is there an additive that'll eliminate this cold weather problem?
TIA.
JK-NY
01-09-2004 16:34:30
 Re: Snow Plow on a Pickup Truck in reply to Mike Thomasma, 01-07-2004 08:33:25
Be sure you are using the blue Meyer hyd. fluid or equivalent,it has an antifreeze additive that will keep any watewr in the system from freezing which is probably your problem. Changing fluid as recommended will get rid of any water suspended by the fluid.
Richard Fazio
01-08-2004 07:38:28
I think you have water in there also. Meyers recomends changing the fluid every year. When did you change it last? The Meyer pumps are open to the atmosphere. They pick up moisture. Warm it up and change out the fluid.
Bryan
01-24-2004 14:20:50
 Re: Re: Snow Plow on a Pickup Truck in reply to Richard Fazio, 01-08-2004 07:38:28
Meyers freeze-up problem - main pump & cyinders , fluid changed several times could be wrong fluid, please recommend proper repair.
Bryan
01-24-2004 14:05:54
Have a problem with a Meyers plow constantly freezing. Tryed warming it in a heated garage , changing fluid, several times, with little benefit. The colder it is intensifies the problem & even driving down the highway is bad. Heat the fluid areas or even pour warm water at the pump base & it works fine.
Maybe I"m using the wrong fluid ?
Please recommend suggested repair or fluids THX
Jim in michigan
01-08-2004 07:21:22
we had some water in ours and it would do that,,,Jim
RayP(MI)
01-07-2004 17:00:45
What does Meyer suggest for fluid? Sounds to me as if the fluid is getting too stiff in the cold. My Monarch pump uses Dextron II, and I have no trouble even in the coldest of weather. But then, my pump is mounted on fender well under the hood too, which probably helps once things get warmed up under there. Are you sure you've got the recommended fluid?
Van
01-07-2004 08:55:50
Had three in our fleet, had one that did it all the time, finally found the soliniods were sticking due to moisture at the top of the system. Valve were corroded and we changed them out and it fixed the problem, You may be able to just clean them up.
Van
