Tool Talk Discussion Forum
wood/coalburner
RICK
01-06-2004 18:50:35
please excuse me for this has nothing to do with tractors or equip.but im looking for info on the united states stove co. s.pittsburg tennesse.im wanting to put this in my farm shop but need a couple parts any help will be app.
Scott Green
01-08-2004 04:47:47
 Re: wood/coalburner in reply to RICK, 01-06-2004 18:50:35
Last year , propane heat cost me $2,500.00 to heat my house(1750 square feet). House is long , so heat was uneven. Put Hitzer coal stove in basement this year. Now I'm heating 3500 square feet , due to heating basement and house. Nice even heat through out. Every now and then , my furnace may kick on. But all it's doing is pushing a little more warm air from the basement , to the house. All the air/duct work in the basement is preheated. So far this year , I've went through Approx: $250.00 worth of coal. My propane bill has been $8.40. My wife also cooks daily on gas stove , so that uses up a little gas. I have the Hitzer model 50-93 hopper model w/blower. Very basic and practical stove. I've heated with many different stoves. This is my first Hitzer. Very happy so far. One thing about the dual fuel(wood/coal) stoves , you get something inbetween a wood stove and a coal stove. Neither one is a true wood stove , or a true coal stove. A true wood stove and a true coal stove are designed completly different. So , if your going to burn wood , buy a wood stove. If your going to burn coal , buy a coal stove.
buickanddeere
01-08-2004 05:06:43
 Re: Re: wood/coalburner in reply to Scott Green, 01-08-2004 04:47:47
The name excapes me but there is a wood/oil stove or furnace with variable air dampers. Set 10% airflow up through the grates and 90% preheated air to mix with the gases driven off the hot wood above. For coal 90% of airflow is up through the grates and 10% of the fresh air in to mix with the coal gases above the grates.
Kens640
01-07-2004 09:42:10
Rick , I 've had a Brunco woodstove which is built also to burn coal in my garage for years . As far as I'm concerned , you can't beat them . I know another guy that has the newer model in his auto repair shop & is well pleased with it too . As a matter of fact he had a newer old motor oil burner in before & couldn't keep warm . Get the type that you can put ductwork to, so you can direct your heat around your shop . It's American made too . Support America .
Robert Cornell
01-07-2004 05:44:36
www.usstove.com
I have used the wonderwood wood burner for years, in fact, both grandparents and my father have heated their houses with one. I have heated my garage/shop (an old service station) with one for going on 12 years now and just bought a brand new one at Fleet Farm for my house. They are nothing fancy but really do the job! Most parts are available including grates, etc... Great stove and very efficient. I can load mine up at 8:30PM and still have a really good bed of coals at 6:30AM (it was -3 deg here this morning). The only thing I didn't care for on the new models was the EPA required holes in the fire door and ash door to create a "minimum burn." I fabbed an adjustable draft control to cover these holes (the old stoves never had them) - leave it to the government to screw things up because a few folks don't know how to keep their chimney clean.....
jake
01-07-2004 08:43:52
 Re: Re: wood/coalburner in reply to Robert Cornell, 01-07-2004 05:44:36
US Stove makes wonderwood, wondercoal and Ashley stoves all quality items. They all have non electric dampers and require good seals around doors.
buickanddeere
01-07-2004 04:41:25
For wood and coal capability Keystoker,Hitzer,Harman & Alaska all make dual fuel stoves.
Van in AR
01-06-2004 19:58:31
Are you looking at the Hot Blast wood furnace?
RICK
01-09-2004 16:52:51
 Re: Re: wood/coalburner in reply to Van in AR, 01-06-2004 19:58:31
it could be the hot blast wood stove. do you know anything about it
