Welder Wire Size
walt
08-06-2000 17:43:03
I have a Hobart Handler 135. Was wondering if the .030 wire is a general all around welding wire? Don't plan on anything thicker than 1/8" or thinner than 1/16". And no special metals. Haven't got a gas bottle yet, but will experiment with the gasless wire first.
Dick
08-08-2000 15:32:41
 Re: Welder Wire Size in reply to walt, 08-06-2000 17:43:03
A .030" S6 solid wire electrode will do well for
light material as you describe. .023" is great
for light sheet metal work. The only place I'd
use a self shielding flux cored electrode is outside where you have the wind to contend with.
Self shielding electrode does not run as smooth as a solid wire in the spray mode. There is also increased spatter and the slag is sometimes hard to remove. D
F14
08-07-2000 04:03:19
That's what I use in my Lincoln SP-130T, and I've been well satisfied.
