Tool Talk Discussion Forum
degreasing/cleaning wand
gfe76
01-03-2004 06:23:56
Tried to build a degreasing wand to use with compressor. Used air gun with extension with 1/8" T fitting a few inches from gun with the bottom of T having a 1/8" rubber tube going to a bucket of solvent. Tube would not pickup the solvent because the T did not have a venturi to cause the tube to suction. Where can I get a T with a venturi? Any other ideas? I don't want to a degreasing gun because they are cheap and don't last long.
JMS/MN
01-03-2004 17:34:09
 Re: degreasing/cleaning wand in reply to gfe76, 01-03-2004 06:23:56
Tried doing the same thing last fall. Same results. #2 Son, diesel mechanic, lent me his. Small difference in construction beween my idea and his commercial unit. His works. It's mine. Will buy him a replacement. His tool salesman will be happy too. Working one is a typical blow gun with suction fitting underneath.
Taylor Lambert
01-03-2004 16:56:28
We have a couple import stores here and i buy alot of cheap tools to modify for my shop. I bought a pistol style syphon sand blaster but it wouldnt pick up the sand well. I threw it in the corner and the next night i had a gear box that had alot of thick gunk in it when I tore it down. I took a bucket of diesel fuel and put the siphon it it and hooked it into the shop air. It has a good steady spray that takes the grease away. I also use it to spray my lathes down when they sweat. Just becareful with it and dont over presurize it sometimes it will start smoking if its too high of a pressure.
