Tool Talk Discussion Forum
Welding on vehicle
john
12-31-2003 05:32:53
I need to do some arc welding on a Ford pickup. What precautions if any should I take to protect the computer system. Is taking the battery cables loose enough.
Thanks
john
01-01-2004 17:07:49
 Re: Welding on vehicle in reply to john, 12-31-2003 05:32:53
Thank You all very much for all the advise. Got every thing ready to go today to weld the class 3 hitch on the pickup and wouldn't you know it I run out of oxygen. So had to put it off till tomorrow. Happy New Year to all.....
john
edwinb
01-03-2004 13:29:47
 Re: Re: Welding on vehicle in reply to john, 01-01-2004 17:07:49
If you have just run out of oxygen you were not electric welding so no computer problems anyway
john
01-03-2004 14:19:21
 Re: Re: Re: Welding on vehicle in reply to edwinb, 01-03-2004 13:29:47
Well maybe I need to spell out more clearly.
I was using a TORCH to CUT the hitch off a older pickup so I could refab with my OXYGEN/Acetylene powered chop saw when I ran out of OXYGEN.
But all is well now. Have it welded up and installed on the pickup with no problems. Even took the time to repaint so it looks just like a store bought one.
edwinb
01-01-2004 11:11:18
The usual procedure around here in to have the engine running fast idle + the lights on , also the return clamp as near as possible to the weld area on a clean site for a good connection ,not through a bearing.
RJ-AZ
01-01-2004 06:33:37
I run a 95' Chevy HD3500 W/6.5 electronic diesel engine, this is a field service truck. I have an onboard Miller welder and have done a LOT of welding on the bumper mounted bench vise with no problems to the system in 145K miles. Be a major PIA to disconect the batteries eveytime I weld something, besides I have to keep my ear to the two-way radio and my rock-n-roll.Crane and air compressor need the juice also. Ain't that right parts guy.
Brokenwrench
01-01-2004 06:10:46
I install alot of hitches,and asked a Ford service rep about welding on the vehicles. He said to disconnect the battery(both cables),use a seperate cable (jumper cable) from the vehicle frame to a good ground away from the vehicle(shop column,existing ground rod etc)to carry away any residual electical or static charges,and place your welder ground as close to the piece being welded as possible. When you reconnect the battery,drive the vehicle 10-20 miles in a normal fashion so the computer "relearns" your driving habits which are lost if the computer is unhooked for over 1 hour. This is for 2000 and up Fords,but I have used the same proceedure on GM and Dodges.
Paul in Mich
12-31-2003 18:01:08
John, you also want to disconnect your alternator even tho you disconnect the battery.
Bob
12-31-2003 15:56:01
Connect your welder ground to the specific part you are welding on, and 99.99999% of the time you will nave NO problems with vehicle electronics. To be even more safe, remove the battery cables from the battery, and clamp (VISE GRIP) the postive and ground cables to each other to prevent ANY possibiliy of stray voltage buildup.
John Ne.
12-31-2003 11:02:58
Always try to clamp the ground as close to the weld as possible and always disconnect the battery. If doing extensive welding, it is recommended to disconnect the PCM, the black box. Cause if it is damaged, there goes at least $600. dealership mechanic/john in nebraska
fixerupper
12-31-2003 11:00:45
Good ideas. Keeping the ground clamp right next to the welding and disconnecting the battery is a good idea. Electricity can take some interesting detours. We had a guy working with us who used a welder to charge the pickup battery with the welder set on DC positive with the stinger clamped to the positive battery terminal and the ground on the negative. He did not check the amperage setting on the welder first ( it was set at 250 amps) and had the battery litteraly smoking in no time flat! It was a computerized chevy and when we drove it, the computer was messed up, causing the automatic tranny to be stuck in second gear. We disconnected the battery for a few minutes and that solved the problem for a short time before the problem came back. This guy was an intelligent person and knew a lot about the mechanics of vehicles, but he just had a dumb moment.
hay
12-31-2003 09:05:59
i asked a question like that on a welding talk forum and never got a straight answer. maybe no one really knows what needs to be done to weld safely on a modern auto. i did get some ideas like attaching a seperate ground strap from the frame to a good ground to keep static charge from blowing the computer. not sure if it really works, though. i welded the tailgate on my 1993 F-150 without disconnecting the battery and everything was ok, but some other systems might not fare so well. maybe contact the dealer service manager about it.
Chris Brown
12-31-2003 05:43:31
I have welded on alot of computerized vehicles, unhook the ground cable on the battery and hook your ground lead on the welder to the item you are welding(bumper),that way the current doesn't travel throughout the vehicle where it doesn't belong. I saw someone onetime hook the ground to the rear wheel while welding on the bumper, the current had to travel through thr driveline through the engine and battery cable, It heated the seal in the rear of the transmission and melted the rubber .Strange things happen when people don't think,.
Ben in KY
12-31-2003 08:59:49
 Re: Re: Welding on vehicle in reply to Chris Brown, 12-31-2003 05:43:31
Not sure about the computer, but have no bearings in between your ground clamp and where you are welding. The current will burn spots on the bearings and they will soon fail badly :(
Mac
12-31-2003 10:58:56
 Re: Re: Re: Welding on vehicle in reply to Ben in KY, 12-31-2003 08:59:49
Never seen it myself, but I have heard you can mess up a ring and pin gear along with bearings.
paul
12-31-2003 10:54:09
The clutch linkage on my 7700 Ford came loose from the shaft coming out of the tranny - 20 years old at the time, but a bad weld showed up. Anyhow my mechanic told me to weld it back on at such & such if I can weld at all - save some money. But I though of it before starting, clamped the ground on to the part, instead of running the current through the whole tranny. Made it very difficult to keep the parts together, there was not much to clamp on to & leave room for this poor-farmer welder.
--->Paul
T_Bone
12-31-2003 11:31:49
 Re: Re: Re: Re: Welding on vehicle in reply to paul, 12-31-2003 10:54:09
ahh ohhh, memory trip,
Many moons ago, I'm working for Coors installing some sheet metal duct work on top of a beer bottle washer. This bottle washer was about 20ft wide and 16ft high and washes several thousand bottles at the same time.
Being the novice sheetmetal worker I was, I put the machine ground on at the bottom of the bottle washer, then used a piece of angle iron to extend the ground to the top of the washer to the duct work.
When I came in Monday, maintance had the bottle washer tore down replacing all the bearings that I had fried, several hundred bearings.
No one ever said a word to me.
T_Bone
moonlite
12-31-2003 14:29:52
 Re: Re: Re: Re: Re: Welding on vehicle in reply to T_Bone, 12-31-2003 11:31:49
I operated a welding shop and a customer came in with a trailer used to hau; a Davis trencher on. We replaced the jack as ordered and the driver asked the worker to do a bit of welding on the trencher. Ithe operator had just greased the trencher and my man started welding on the trencher without moving the grtound clamp and he noticed a wire braided hydraulic hose smoking. The best ground was through the wire braid of the hose.
Terry
12-31-2003 05:36:44
Sorry I can't answer your question, but I've been wondering the same thing. I've been needing to weld on the bumper hitch on my truck for months, but have put it off for fear of messing up some of the computer stuff. Anybody know what precautions need to be taken????
Thanks!
Terry
Slowpoke
01-01-2004 01:30:20
 Re: Re: Welding on vehicle in reply to Terry, 12-31-2003 05:36:44
Anything I would weld on has no computer; I'd be worried about the gas tank tho. I know muffler shops use torches and it looks like no problem.
Any advise there?
