Tool Talk Discussion Forum
Trailer Light trouble
Steve
12-30-2003 17:11:23
Rewired a Livestock trailer today. One problem though, When the tailights are on and I step on the brakes, all lights go off. Brake lights work without the tail lights off but not when they are on. Also noticed that the blinker, taillight and brake lights all work over the larger/Upper filliment. Seems like the trailights sould be on the smaller/lower filliment and the brakes and blinkers on the other filliment.
I used the standard brown for taillight to each side and 1 green to the right side and 1 yellow to the left. 1 White for a ground to the trailer body...
Thanks
bob
01-04-2004 09:24:08
 Re: Trailer Light trouble in reply to Steve, 12-30-2003 17:11:23
is it a gooseneck or bumper pull? If gooseneck hitch needs to go to ball & hook up. Dont depend on trailer ground wire by itself. It will ground thru the hitch best.
lc
01-01-2004 18:34:53
Had same exact problem last spring. Most of the trailers you buy don't have the ground wire even hooked up. I ran a ground from where the lights were bolted to the trailer to the plug on the vehicle. Problem solved.
smurph72
12-31-2003 17:36:58
Had the same problem recently. After rewiring the ground pigtails at the fixtures at the rear of the trailer, problem solved.
dcm
Mac
12-31-2003 11:02:43
I dunno, I always ran a ground back to the veh. via the plug connection.
deano
12-31-2003 10:42:10
i agree with previous re: grounding trailer with vehicle your pulling it with....
Dave H (MI)
12-31-2003 07:42:27
If the wires run through the frame, check for mouse damage. They will strip the wires and cause all kinds of trouble.
Paul Janke
12-31-2003 06:24:14
My experience has shown you can't depend on the hitch to furnish the ground. It needs to be through the trailer plug.
Van
12-30-2003 18:25:10
You have a open to ground, check your lights to make sure they are grounded to the trailer frame.
Some ground with a pigtail and some with the mounting bolts.
D.L.
12-30-2003 17:56:19
When I wire, I use an inexpensive probe (with an in-line bulb and a wire with an alligator clip) to just double check my circuits... ground the alligator clip & probe each pin on the connector to make sure which wire is which. In my experience, the MAIN CAUSE of the symptoms you describe is an INADEQUATE GROUND!!!! I usually drill a hole in solid metal somewhere near the electrical connection on the tow vehicle and use a self tapping screw to attach a ground wire for the connector... then do the same thing on the trailer. Then, with the short ground wires and their easily accessible connections on each vehicle, it's easy to re-check the grounds when I encounter lighting problems in the future!
Steve
12-30-2003 20:19:06
 Re: Re: Trailer Light trouble in reply to D.L., 12-30-2003 17:56:19
I did use the old ground wire connection. I'll give that a try in the morning... Thanks for yours responses...
RWK in WI
12-31-2003 06:17:38
 Re: Re: Re: Trailer Light trouble in reply to Steve, 12-30-2003 20:19:06
You can do a quick check by using a regualr battery jumper cable from solid ground on vehicle to a good connection on the trailer frame.
