Tool Talk Discussion Forum
Craftsman Air Compressor Motor
Mark L
12-30-2003 12:25:16
I have a Craftsman 2hp 12gal compressor, when I start it up, it runs for 30 seconds and shuts off . It sells like the brushes went on it. Looking for help with eletric motor or brushes part no. Help????
Bob
12-30-2003 19:33:42
 Re: Craftsman Air Compressor Motor in reply to Mark L, 12-30-2003 12:25:16
When your motor starts, a governor weight mechanism (centrifugal switch) kicks out as the motor comes up to speed. If these contacts fail to open, rapid overheating of the start windings and tripping of the motor protector will occur in a half-minute, or so. Sound familiar?
Common causes for the start switch not to open?
(Normally these contacts are inside the motor endbell, oposite the output shaft.)
1.) Contacts welded together in start switch. May work for a while if you separate them, and carefully file the contacts. A local electric motor shop probably has, or can get a new switch.
2.) Motor has developed too much endplay, and the centrifugal mechanism does not contact the switch to push it open. Causes... bad bearings, worn thrust washer(s), or a belleville washer that spring loads the ball bearings to take up endplay has broken.
3.) Electrical short in the windings that has the same effect as the centrifugal switch not opening.
Mac
12-30-2003 15:21:32
Shouldnt be any brushes in that motor. A/C, probably a cap. start, 110volt. Motor. Sounds like if equipped, the capicitor is bad. Run windings not kicking in. Any motor shop should be able to get you an equivalent Cap. or motor. Run the model number of the comp. on the sears parts web, maybe you can get a better idea of the motor size there. You can remove the belt, if equipped, unplug the motor and turn it by hand, see if it is free.
