Tool Talk Discussion Forum
Nibbler or shears for cutting steel panels?
Bryan
12-30-2003 09:28:19
what works better and makes a cleaner cut? Opinions? I'm putting up a pole barn in the spring and want to start getting ready. Thanks fellas!
Bishop
12-31-2003 14:39:28
 Re: Nibbler or shears for cutting steel panels? in reply to Bryan, 12-30-2003 09:28:19
The nibbler works great once you get used to it. It's really good for cutting holes in sheet metal too. It's tricky, and your can get off your mark real easy, but it's worth having.
Pick you up a large magnet on a shaft about $20, it will pick up 100% of the shavings after the job is done. With out the magnet, you will leave a real mess of thousands of sharp cresent shapped metal daggers.
T_Bone
12-31-2003 11:14:21
Hi Bryan,
A nibbler cuts little nibblets, about 3/32"long x 3/8" wide. If not held correct, a nibbler will self feed and be hard to control a straight cut. Nibblers are used mostly on 12/14ga material for ruff cutting.
Doubble cuts, cut a 1/4" wide strip out. Very easy to control, cuts round surfaces easy, and leaves a very nice finished edge. Can self feed but that don't happen offten and easy to stop when it does. Cuts straight/circle lines more easy. Cutting Capicity too 18ga.
Uni-shears cut like a pair of scissors, so one side of the material has to be lifted to give relief too the cut. Great for accurate cuts on both straight and round cuts on "flat" sheets. Capicity 16ga. Doesn't work well for cutting decking or heavy ribbed sheeting.
Hand shears, M-1 right cut green handle, M-2 left cut red handle, M-5 bull dogs red handle (great for cutting standing ribs) made to cut heavy material 18ga. Wiss still makes a good hand shear, about 20ga capicity. I use the M5's for my throw away shears for abuse cutting, cutting too thick of material.
Makita 5", model 9005, side grinder with a 6"x3/32" cut off wheel works well for cutting several sheets to the same length, stacked. At 10,000rpm it is a very high risk injury tool if not used correct. A full face shield with safety glasses, leather gloves, is minimum required. If you smell leather burning, it's time to go get stitchs. Cutts like butter even thru SS with a straight edge depending on users skill. 1/2" SS plate cuts nicely. does leave a burr that needs to be removed.
My choice for working siding/roofing:
M1,M2, M5
doubble cuts
Makita 5"
Milwaukee drill motor. cordless works well and depending on construction method, two drill motors.
T_Bone
Bus Driver
12-30-2003 16:19:34
The nibbler removes some metal, so some loss of panel size results. Most shears do not remove metal. Nibblers are available that will cut heavier gage sheet than will portable shears. I find the shears more useful for building panels.
Greywolf
12-30-2003 13:44:44
A while back this subject was brought up.
One solution was using a heavy piece of wire anchored at one end on a board. Tin laid over the top, step on sheet to anchor it and pull the wire up to cut the sheet. Any angle can be cut with ease so was said.
Maybe that poster will post again on this one for a better description.
cutter
12-30-2003 21:27:32
 Re: Re: Nibbler or shears for cutting steel panels in reply to Greywolf, 12-30-2003 13:44:44
piano wire for the cuts as regular wire will break on the second cut skillsaw blade turned around backwards will last forever but be sure to wear safety glasses
buck
12-30-2003 13:08:44
Go with air; 20 gal compressor,nibbler, shear,cut-off tool,air chissel right angle grinder, body saw, ratchet,impact wrench.Cost about the same as electric shear,nibbler and battery drill/driver but you will have all the bases covered. If I were doing this job and had to rely on one tool it would be the air chissel with body/panel cutting bit.Don't overlook the possibility that for the long straignt cuts you may be able to score with a razor knife, bend and pop apart.
kraigWY
12-30-2003 11:52:18
Depends on what you are cutting, I use both. But like below an abrasive blade on a cicular saw works good. For layout work on bigger projects I have an abrasive blade for my table saw. That makes clean accrute cuts.
GlenninPA
12-30-2003 12:12:21
 Re: Re: Nibbler or shears for cutting steel panels in reply to kraigWY, 12-30-2003 11:52:18
I watched the Mennonite guys when they assembled
my pole barn this past fall. They used battery pak
nibblers for the vertical cut. For the horizontal
cut they used hand shears.
Kevin
12-30-2003 11:24:02
A combo of nibbler and cutting blades, with shears for anything complex. A nibbler is fast and easier on the body.
markct
12-30-2003 11:13:00
a skilsaw and a metal cutting abrasive blade is what most around here use
Van
12-30-2003 09:39:07
Bryan, Either one will do the job but the bosch electric nibbler that I have is a lot faster and easier on the hands. Have also cut some with a plasma cutter and a guide board, more expensive but you may have a need for one in the shop anyway. It cuts like butter.
Van
