I would not recommend welding to fix the top of an anvil unless you are going to do the entire face. Traditional anvils were made by welding a piece of tool steel to the top of a wrought iron body. The anvil was then heated to red heat, quenched to harden the steel, and then tempered by bobbing it out of the slack tub, letting the residual heat in the wrought iron body warm the anvil up to the proper temper before a second quenching. Imagine doing this with a 200# red hot anvil! Welding will anneal the area around the weld and create a soft spot. However, if you are going to cover the entire face of the anvil, using hardfacing welding rod, a suitable face hardness can be achieved even if the underlying steel is annealed. If you choose to do this I would recommend looking through the archives of www.keenjunk.com as there are detailed explainations on this site. The normal way of fixing rounded or chipped edges is with a grinder. Be careful not to grind all the way through the steel top. You need to know that most blacksmiths like at least one "softened" (rounded) edge on their anvil anyway. Good luck in whatever you decide to do. Cliff
