Tool Talk Discussion Forum
Well while we are on the subject of tool setups
ShepFL
12-28-2003 11:35:55
What do y'all use for your table saw and miter saw?
Is it dedicated space or mobile. Since most of my shop work is with iron I have been thinking of putting my table saw (10") on a mobile table saw cabinet. (Overall dimensions estimated at 24" high x 40" wide x 24" deep)
Figure it would add some weight and stability, have drawers and hooks to hold some tools/blades, roll it out of the way for storage. Mostly, it would turn all that wasted space under the saw into much needed storage space. Perhaps in the future include some type of sawdust collection system in the cabinet and an outfeed table.
Also what do you think of a rotating top table that you could attach small bench top tools on one side (miter saw), yet still have additional work top space when you need it on the other side. This would also be mobile so it can be stored out of the way when not needed. Estimated dimensions: 33" h x 96" w x 24" deep.
Just thinking out loud,
Thanks
Chester
12-28-2003 20:24:51
 Re: Well while we are on the subject of tool setup in reply to ShepFL, 12-28-2003 11:35:55
Tablesaw and mitre saw are both mobile. Tablesaw re-assembled with both extensions to the right and a mobile stand welded up out of 1 1/4" sq. tubing to fit under the whole length. Storage under the bottom portion, jig storage directly below the extensions. A sheet metal chute was fabricated under the saw, angled down to dump the sawdust out the back into a box directly below the motor. Swivel castors on the right, the protruding horns of the fence guide tubes act as handles to maneuver the saw. On the left, are fixed wheels on an axel that pivots in the center, making everything self levelling. With about 3" dia wheels I find no locks are needed. Moving the saw around keeps the sawdust moving into the box and requires very little help and captures 90% of the sawdust. Made a similar setup for the mitre saw just over 3 Ft long and the width of the saw. The back section of the top is about six inches lower which accomodates a 9" sanding disc on one side and a belt sander on the other. Storage below that section. Below the saw at the front is a thickness planer which stays there for small jobs or can be moved onto a higher stand when needed. Same type of construction with the swivel wheels under the saw and a handle like on a shopping cart is there also. Again no locks needed and no provision for dust collection as I work outside. A similar setup was made for the jointer, a little wider so a verticle rack holds all the pipe clamps ,etc. and adds some stability to the jointer. Found it was top heavy without that extra width.
Gene Davis (GA.)
12-28-2003 18:40:57
I have all my wood working tools including a 20" band saw on wheels, 2 regular casters, and 2 that lock. Primary shop use is metal work, so I roll the wood work tools out as needed and then they go back to one wall side and are out of the way for most of the time. Gene
Oklahomatractorrebuilder
12-28-2003 18:03:38
We use dedicated space for both the metal working tools and the woodworking tools. Use the rear 15 feet of a 40 by 70 for the wood part with a false celing/shelf 8 ft off the floor to store the extra tractor parts on and the rest of the 40 by 70 to park our restored tractors in. Use the left 10 feet of a 40 by 60 for the metal shaping tools and the rest of the shop is used for restoring tractors and working on customers vehicles. This setup gives us 600 sq feet of floor for woodworking and 600 sq ft for metal working.
D.L.
12-28-2003 17:15:14
since I'm a woodworker and a metal worker (fabrication & machinist) I share your problem. You might check back issues (within the last year) of wood magazine. If memory serves, they did a series on their "idea shop"... a system of tables/cabinets/etc for holding & organizing just about everything in the wood shop. They had some really good ideas that would result in a versatile and organized shop... had plans for building it too. No need to re-invent the wheel when there are lots of ideas floating around!!!
wdTom
12-28-2003 14:14:48
Well this probably won't help you much, but my table saw doubles as a work table as my work bench always seems to be full. The table saw gets cleaned off every once in a while when I need to use it. A good idea would be to put a piece of plywood on it and use it as a table.
Mac
12-28-2003 12:45:08
Shep: We mounted our radial saw on a good size cabinet. Has the locking coaster/wheels on it. Also used the cabinet for saw blades and wot-nots pertaining to same. Works great as you can pull it out in the middle of the floor and when finished shove it in a corner. Never tried a table deal like you mentioned, but arranged for your convenience, I think it would work great.
