Tool Talk Discussion Forum
reclaiming a Detroit Diesel 53 series crank
Rob Johnson
12-27-2003 01:26:22
If I were to have a DD 53 series with a well worn crank , what would be the best way of reclaiming it ?.
EIL
12-28-2003 00:44:40
 Re: reclaiming a Detroit Diesel 53 series crank in reply to Rob Johnson, 12-27-2003 01:26:22
I did once have to change the crank on a david brown 1210 because it had been ground to .030" and the heat from grinding it caused one of the throws to crack and fail.
jdemaris
12-27-2003 19:38:52
I'm not sure I understand your question, but if you're talking about journal wear, either have it ground undersize, or spray welded and ground back to standard size. Either way, no big deal.
Rob Johnson
12-27-2003 19:47:47
 Re: Re: reclaiming a Detroit Diesel 53 series cran in reply to jdemaris, 12-27-2003 19:38:52
I was wondering what were the different techniques used , how they relieved stresses etc. I don't even know what was used on a DD 53 crank , and how that effects techniques used , and the success rates. Regards Rob Johnson
jdemaris
12-27-2003 20:06:25
 Re: Re: Re: reclaiming a Detroit Diesel 53 series in reply to Rob Johnson, 12-27-2003 19:47:47
I've rebuilt a lot of diesels, mostly John Deere but also a number of 2-53, 3-53, a d 2-71 Detroits. Usually, if they had to go smaller than .020" undersize, we had them spray-welded and ground to standard. I don't understand why a conventional crank regrinding requires stress-relief. Perhaps after spraywelding, but I've never heard anything about it. They'd get magnafluxed and checked for stress-cracks, but that's about it. As far as cranks go, I've never had any problems or failures that related to regrinding or spraywelding. Had a few Chevy 6.2 diesel cranks break, but that had nothing to do with rebuilding.
buickanddeere
12-27-2003 19:30:17
If it's just the crank ends, a Speedi-Sleeve works great.
EIL
12-27-2003 02:51:50
You could get it shaved .010", .020", or .030" depending on how bad it is worn or if it is scratched or gouged. Is this a 3 or 4 cylinder? I had torn appart, put back together, and got running a 4-53 detroit at vo-tech school a few weeks ago and am sceduled to overhaul a farmers 3-53 pretty soon so if you have any questions, I might be able to help you!!!!! !!!
