Tool Talk Discussion Forum
Remote Hyd Valve
Cary
12-26-2003 12:06:47
I've got a 2002 Massey Ferguson 231 S...need to add a remote hyd valve to operate a grain drill. Massey wants 600.00 just for the part....can't I buy something "aftermarket"? Thanks....
scotc
12-29-2003 20:42:07
 Re: Remote Hyd Valve in reply to Cary , 12-26-2003 12:06:47
tsc has a setup with 2 remote valves in the same casting, why not get hoses and couplers to plug it into you existing outlet and run your 2 circuits from there? also can be moved from one tractor to another if needed.
David in MD
12-28-2003 01:59:06
Assuming you already have one remote outlet and need another this will work. I made one for Dad's 4010 by using a 2 port 2 way valve from Northern Hydraulics. This valve has 2 input ports and 4 output ports and a selector knob. I used short sections of hose to connect to the tractors existing outlet and bolted the assembly above the outlet. I then connected the proper female quick connectors to the output ports. Dad used it for his moco. Pull the selector knob up to swing the tongue then push the knob down to raise and lower the machine. Still cost about $200 but cheaper than factory or $400+ electric multiplier like Shoup sells.
Alvin n Ms.a
12-26-2003 12:21:24
Go to this site. bigdeantipindex
BobInMN
12-26-2003 13:33:13
 Re: Re: Remote Hyd Valve in reply to Alvin n Ms.a, 12-26-2003 12:21:24
Alvin,
Did you use to be a Captain in the Army?
Bob
