Tool Talk Discussion Forum
Specs for Compressor Recommendations
Lawrence Au
12-24-2003 11:17:50
Hello, I'm considering purchasing a compressor. Brad nailing, impact wrench, air grinder, ratchet, paint spraying, and of course inflating stuff, would be my primary uses. I'm wondering if you could tell me what kind of specifications I would need in a compressor to be able to run these tools. Thanks! :)
Lawrence
Roger
12-24-2003 14:13:40
 Re: Specs for Compressor Recommendations in reply to Lawrence Au, 12-24-2003 11:17:50
A good oil lubricated 20 gallon (or thereabouts)portable compressor would be a good bet. If you have to take the machine with you, a small portable twin-tank Emglo unit would fit the bill. Don't expect to run an air grinder for very long. Anything that runs constantly will gobble up air like nobody's business (grinders,sanders, sandblasting). Short duration operation like impacts and ratchets are usually not a problem, and all but the very smallest compressors will handle nail guns with ease. You can even get some rechargeable nailguns with a built in compressor. Look for about 6 to 10 CFM at 90 to 100psi., depending on how much you want to spend. I would avoid oilless compressors, as they are pretty much disposable, and troublesome in my experience. They are also extremely noisy. Just obnoxious to be around. All of this depends on your budget, of course. Decent brands are Campbell Hausfeld (oil lubricated single and twin cylinder models), Emglo, Quincy, and Champion, to name but a very few. Ingersoll Rand also makes a very nice cast-iron pump compressor for home use. DeWalt and Stanley-Bostitch are also pretty good. Ignore almost all horespower ratings, as they are usually boldfaced lies. CFM is the only reliable method of gauging air output, and only at 90 to 100 psi. Ignore CFM ratings at 40 or 45 psi as virtually nothing operates at that pressure besides blowguns or paintguns.
