Tool Talk Discussion Forum
Ingersoll Rand Air Compressor Question???
Robert(AL)
12-22-2003 19:47:18
Will the tank regulator fail due to cold weather?
Tank pressure set at 150 psi. Turned it on and it failed to shut off at 150#. The pop off valve released the pressure down to 100#, sounded like a jet engine. I turned off the power, and haven't tried it again. It's a T-30 5hp motor.
Any suggestions appreciated.
Roger
12-23-2003 16:42:19
 Re: Ingersoll Rand Air Compressor Question??? in reply to Robert(AL), 12-22-2003 19:47:18
Check the pressure switch contacts. Usually the contacts are melted closed when a compressor fails to shut down. You might consider a heavy-duty pressure switch if this is the problem. Furnas sells one that is good for 28 amps. Otherwise, you need a magnetic motor starter.
VaTom
12-23-2003 04:56:35
I have a similar IR compressor that lives outside under a roof. No problems with mine down into the teens, other than starting when cold. Did you look at the switch?
Bob
12-22-2003 20:04:23
You may have ice in your pressure switch. (Or unloader valve, if it is gas powered.)
