Tool Talk Discussion Forum
knipco
george
12-22-2003 17:33:58
Had my knipco going but more fuel in it do not know what was in it before.I put kerosene and the thing will run for about30 seconds and the auto shut off will make it shut off.Is it possible i have the wrong fuel in it,it was not smoky in the garage before i refuel it. It run good before to. or what eles is doing it? thanks
gr
12-24-2003 16:36:37
 Re: knipco in reply to george, 12-22-2003 17:33:58
Make sure siphon line is open- mine plugged up, couldn't suck fuel. Adding fuel stirs up crud off bottom of tank and plugs suction line. Good luck.
test
12-23-2003 04:14:58
jumper 2 eye wires together should start run tim
tim in wi
12-23-2003 04:10:28
photo eye bad not seeing fire shuts down . cloged fuel lines filter . try eye first gl tim
george
12-23-2003 20:12:34
 Re: Re: knipco in reply to tim in wi, 12-23-2003 04:10:28
tryed to wire nut the eye wires togeather and still did not keep runing,i cleaned the filter in the siphon line and air filter waiting for air filter to dry now.
