Tool Talk Discussion Forum
Which brand is better?
Henry
12-18-2003 10:25:52
There are three cordless Drill combo I need to choose one. Craftman 19.2 volt, RYOBE 18 volt and Black & Decker Fire Storm 18 volt, I am trying to choose one from them, but still can't make the decision. Please give me some advice! Thank you!!!
Henry
12-22-2003 01:03:59
 Re: Which brand is better? in reply to Henry, 12-18-2003 10:25:52
Thank you for all of your advices! Finally I brought the Ryobe drill combo 18 volt(5 pieces) from Homedepot for $135. I think this is very cheap for the whole thing, don't you think? Now, I am hoping it can last longer than I expected, which is 5 years. Thanks again, and have a happy holiday!!! :)
john d
12-20-2003 20:42:53
I have a 5-year old Black&Decker 18 volt Firestorm that is a gem. It has had heavy use, with no problems. You can get replacement batteries in most home improvement stores, Wal-Mart, or Target. It's not the equal of a DeWalt, or some of the other high$ brands, but I have no complaints. My son has a Porter Cable 18 volt that I like a LOT.
Ludwig
12-19-2003 12:04:27
I have a 12v Firestorm drill and I like it fine, its got as much power as I need most of the time. I've had it about 3 years and it does okay. I just bought a second battery which is handy.
My Dad has a 12v Firestorm, but its the angle driver thing. His is actually more power and is more frugal on the battery. The cheezy thing is that the batteries don't interchange. Dad's uses a slide on pack and mine uses the push in kind.
Other than that the only thing about Dad's is that its really an electric screw driver because it only uses the bits it doesn't have a real chuck.
Cliff Neubauer
12-19-2003 10:06:33
We bought a Craftsman 16.8v cordless drill two years ago, the drill itself has held up pretty well for what I have done with it but last summer one of the batteries quit taking a charge so I'd like to replace it with a professional grade model like a Makita or Milwalkee. One of the reason's I am looking at those brands is because they also make 18v cordless impact wrenches so the batteries and chargers would interchange. I think the Craftsman would be fine for home use but I sure wouldn't want to try and make a living with one.
Slowpoke
12-19-2003 09:50:40
Check for a recall of B&D Firestorm drills. I have a 12v Makita bought used 10-12 years ago, bought one battery just this year. I have removed the guts from the case of a dead battery and added a 15' extension cord so the drill can be run off the 12v truck battery if the Makita batteries die in the field. And I use the drill frequently.
Wayne
12-22-2003 18:49:12
 Re: Re: Which brand is better? in reply to Slowpoke, 12-19-2003 09:50:40
So one could run any 12volt drill off a truck battery. Is one terminal positive or doesn't it make a difference? Have you run it enough hours you know it causes no damage? Thanks!
Slowpoke
12-22-2003 23:42:31
 Re: Re: Re: Which brand is better? in reply to Wayne, 12-22-2003 18:49:12
Wayne, Joe is right about the connections. I used a 16 gauge, 15' flat extension cord. The wire with the ribbed insulation is connected to the positive terminal of the drill battery and the wire with the smooth insulation to the negative terminal. On the other end, you can use clamps, connecting a red clamp to the ribbed wire and a black clamp to the smooth wire. That way your drill will run normally when the red clamp is on the 12v positive terminal and the black clamp is on the negative terminal of the auto/truck battery. Mine is wired to use the lighter outlet on the dash. You will have to figure out how to open your drill's dead battery to remove the contents, connect the wires, and be able to put the shell back in the normal way. It may take a little cutting/filling of the drill case to get the wire out. My battery is completely inside the drill case. Depends on the brand and model you have. Ask for a couple of dead batteries at a service center if you don't have your own.
You may also notice a slight slowing of the drill due to the voltage drop in the long cord. If you can fit a 14 gauge cord it would work better.
Joe (Wa)
12-22-2003 21:45:40
Wayne, if I may butt in? I run a 12v Porter Cable off vehicle batteries. Hook-up the terminals so it will rotate in the direction of the normal switch position. If you hook it up backwards it will simply run opposite the switch position.
Running off a 12v truck battery is the same as running off a battery pack with a higher ampere hour capacity. Joe
Wanye
12-23-2003 18:15:33
 Re: Re: Re: Re: Which brand is better? in reply to Joe (Wa), 12-22-2003 21:45:40
Thanks! I need to drill some 3 foot fence holes through Border Line trees and the battery pack is too small.
Terry
12-19-2003 06:48:16
I've never had a B&D tool that wasn't junk, but then again I compare them to top grade tools. I have a Porter Cable cordless -- had it maybe 10 years. When it dies (if ever) I'll buy another, can't give a better recommendation than that!
Terry
Brandon
12-19-2003 06:05:41
Where I work they bought a 18v Rybi set and it is under powered. The set they bought is the one that came with the chop saw.rotory zip tool,sawzal,drill,flashlight and 5 inch skillsaw. The flashlight is the best tool in the kit. I know that Dewalt is more but in the long run it is well worth it.It will also last so much longer.
rustyfarmall
12-19-2003 04:49:49
Go with the Black and Decker Firestorm. I own one, and have been very impressed with the performance. Only one problem, after 2 years, I had to buy a new recharging unit, it cost me $25. The battery packs have given no trouble at all.
Gary in TX
12-18-2003 21:33:16
Henry,
Your best choice would be to consider first of all, is this for personal or professonal use? For perosnal use I think any of the 3 you listed would be ok, for professional use then I would say go on up to the higher end of the price range drills.
You Listed 3 LOSERS
12-18-2003 20:38:21
These are all 3 pert near worthless. Get a Makita, Hitachi, DeWalt, or other good brand.
Mark
12-18-2003 19:12:20
Just bought a Hitachi 18v. Best drill I ever had. At Lowes $135.00. Last drill a Sears 14v. Hitachi is 3 times better. By the way it was my first Hitachi purchase. Came with 3 batteries, flashlight and case.
tools
12-18-2003 20:52:13
 Re: Re: Which brand is better? in reply to Mark, 12-18-2003 19:12:20
Hey Mark,
Use that Hitachi a lot while the warranty is still good. I bought the same drill, loved it! BUT, the batteries didn't last 3 weeks, and I've seen similar reports made by others on the Amazon/Tool Crib site.
I have a couple other corded Hitachi products and really like them, have had them long enough to trust their quality. I may have just gotten that 1/2 of one percent. I decided to just turn it in instead of getting a replacement, but that was just a "I was mad at the time" decision!
I would definitely recommend this drill over the Craftsman/Ryobi. Don't know enough about the B&D. Although I notice the head doesn't swivel on the B&D flashlight, that's a negative.
Tools
FWIW, I went with the Brute series by Bosch, quite in a class by itself. Not in everyone's pocketbook I admit, but I use the tools professionally.
brian
12-18-2003 14:49:03
Henry. Black and Decker is the parent company of Dewalt and I think the firestorm batteries are the same as the Dewalt batteries. If I had to chose between the three choices, I would go with Black and Decker. I buy all Dewalt tools and the style of the Firestorm is very simular to the Dewalt power tools. Never had a Firestorm tool but Dewalt has always held up very well for me. I have a couple of Ryobi tools and the quality is good. Just my .02 worth on the subject.
HMJ
12-18-2003 14:43:24
You Get What You Pay For. Hilti Millwauke Dewalt
RZ(Wa)
12-18-2003 14:20:26
We've bought six of the Black&Decker Firestorms and all but one has held up very well. The one that didn't was due to a high impact stress-test (a trackhoe walked on it). We stay away from Sears, as a general rule, since their power tools do not use standardized hardware and attachments, so you are stuck with purchasing attachments only from Sears.
jim
12-18-2003 14:00:36
got a craftsman 19.2 with a trim saw, light and drill, it has wokred great for a year now, it is not used a lot though.
Dave H
12-18-2003 13:16:07
I would price replacement batteries first. Sears has a way of using odd voltages so you have trouble with replacing plus they want a lot of money for theirs. I only buy Sears hand tools now. Have you looked at Makita or Dewalt?
Henry
12-18-2003 13:26:51
 Re: Re: Which brand is better? in reply to Dave H, 12-18-2003 13:16:07
Makita and Dewalt, they are too expensive for me. I asked someone in sears(He looks pro.), he said, "Ryobi is better than Craftman." So, I am planning to buy Ryobi 18 volt drill combo at HomeDepot. I wanted something that is powerful enough to do heavy works(Like drill a hole in a concrete wall), and also last longer. You think Ryobi 18 volt can do it? Thanks!
D.L.
12-18-2003 14:53:32
 Re: Re: Re: Which brand is better? in reply to Henry, 12-18-2003 13:26:51
Good thing he LOOKS like a pro, cause if he were depending on his knowledge to survive, he'd starve!!! Ryobi MAKES Craftsman tools and they're BOTH junk!!! (I've worked for a nationwide seller of tools & equipment for nearly 10 years) I'd have to agree with a previous post... ya get what ya pay for! I've had a Porter Cable 19.2v for several years (bought it when they first came out) ... it'll do ANYTHING, and I haven't had a moments trouble with it! Prices have come down considerably too!!!
Henry
12-18-2003 12:26:45
Is there big different between 19.2 volt tools and 18 volt tools? If there is not too big different, I will prefer 18 volt. Don't you think?
Mac
12-18-2003 12:36:41
 Re: Re: Which brand is better? in reply to Henry, 12-18-2003 12:26:45
Dont think there is a lot of difference myself. 18 or 19V. I got the 19V last time cause it was on sale, plus a trim saw and lite for 125 bucks was included. Gave my 12 V to grandson, but I could tell a difference betwix the 12 and 19 volt.
Henry
12-18-2003 12:40:34
 Re: Re: Re: Which brand is better? in reply to Mac, 12-18-2003 12:36:41
Thanks!
Mac
12-18-2003 11:08:09
Craftsman is as good a choice of the 3, at one time I think ryobi and B&d both made drills for sears.
