Tool Talk Discussion Forum
Bobcat hydraulic problem
Chris
12-15-2003 09:55:31
I have a Bobcat 721 that has no hydraulic control. It went down gradually and now it's doing nothing at all. I have checked the fluid and changed the hydraulic filters. I also tried charging the pump by pouring fluid directly in the low pressure side until it ran out the high pressure side.
The next thing I am going to try will be to apply air pressure to the hydraulic tank through the fill hole to charge the pump.
So far I'm getting no where, any body here have a suggestion?
Thanks.
Ray
12-16-2003 16:01:43
 Re: Bobcat hydraulic problem in reply to Chris, 12-15-2003 09:55:31
Chris check the coupler between the motor and pump it may be worn to the point that it slips under the slightest load.
Jailkeeper
12-15-2003 15:03:28
Sounds like you need a new hyd. pump. You said it happened gradually and now it has no hyd. pressure at all, that is a good indication of a bad pump.
