Tool Talk Discussion Forum
2 TON SHOP CRANE
POP
12-15-2003 06:38:44
thinking of buying a moveable shop crane for pulling engines and for removing tractor wheels with weight ect. any body have one and where did you get it thanks POP
Scott Green
12-16-2003 04:42:16
 Re: 2 TON SHOP CRANE in reply to POP, 12-15-2003 06:38:44
I have a 2-1/4 ton one. Bought it for lifting 500 pound coils , reaching into trailer , and setting coil on machine. Works great! I can see many other uses for it also. On sale at auto parts $199.00
markct
12-16-2003 05:19:35
 Re: Re: 2 TON SHOP CRANE in reply to Scott Green, 12-16-2003 04:42:16
continuos rain gutters it sounds like you do? my father did that for many years, they used a tractor and boom pole and later a forklift with a boompole.
Chris Brown
12-15-2003 18:18:31
I got a 1 tonner from homier,the traveling tool people. It is a little lightweight but I couldnt get along with out it.It does fold up for storage.A 460 and auto is all it wants,and with that I would'nt get under it. But it only cost $89.00
farmerherron
12-15-2003 17:24:38
I have a 5 ton Contrax gantry crane and don't now how I made it before. Great for splitting tractors, lifting engines, changing tires, adding duals, and many other projects. I found it on ebay, they usually have a couple listed. Good luck.
ralph
12-15-2003 17:04:06
We had a factory made one, it was so handy we overloaded it and it folded up. Built a much heavyer one and again it was so handy we bent the boom on it and had to make that stronger. Must have got it right as it has several years on it and still going good. The legs are the rails from a F 30 Farmall and although it doesn't fold up the legs are made to swing in and out to make it wider or very narrow.
Unimog
12-15-2003 13:29:31
I have a 2-ton EX-CELL that a picked up at Sam's
Club. Well made, USA built I believe, and cost
around $200. It does not fold up for storage, but
I think the ones in Sam's now do fold up.
Don c
12-15-2003 08:08:30
Got mine a couple weeks ago from TIP Tools in Canfield Ohio. It is also 2 ton with a larger ram, have used it to remove tire and rim from my 60, works great. Paid 199.00 on sale. Be sure to get one with that folds up as it takes up less room in shop. I see all kinds of things that it will be used for later. Hope this helps.
Don c
