Tool Talk Discussion Forum
6 hp 30 gallon air compressor
darren logue
12-14-2003 16:18:29
my compressor is a year old and havent used it that much my problem is the drainvalve leaks air at bottom of tank it will not close turned clockwise and counterclockwise all the way even took out and replaced with same valve is the valve defective?
Jeremy
12-18-2003 10:56:11
 Re: 6 hp 30 gallon air compressor in reply to darren logue, 12-14-2003 16:18:29
I had the same problem with a Craftsman and was able to return it under warranty. The warranty on air compressors one year after the purchase.
Jeremy
Mac
12-14-2003 16:44:28
Probably small rust particles preventing it from closing. It may have an 0 ring also. Seen both kind. Seen some fellows run a small pipe and elbow out to the end of tank and install a small ball valve.
