Tool Talk Discussion Forum
110 volt MIG welders
Eric Rylander
12-14-2003 09:41:32
I have been shopping for a 110 volt MIG welder, I have some auto body work (thin gauge) stuff to use it on as well as small projects.
I am looking at either a Lincoln Handy Mig or the Lincloln Mig Pak HD.
I have looked at Lincoln's web site and can't find what if any difference there is between the two. The sales folks at Home Depot don't know a welder from a miter saw so they can't help.
Eric
RJ-AZ
12-14-2003 18:21:14
 Re: 110 volt MIG welders in reply to Eric Rylander, 12-14-2003 09:41:32
I have a Lincoln 110 volt machine with flux core wire and it is real handy and super portable. My recliner broke a strut and it was easier to pack the welder into the living room than the chair to the shop. (I might be a redneck) For outdoors windy conditions it works great also.
BobCaesar
12-14-2003 10:37:28
I've got a 110v Hobart which is just fine. Got a much bigger Miller which is super. If you start doing much with it you'll want the higher voltage mig. However, for mild steel up to 1/8" or maybe a tad more the 1120v is fine cause you can plug & play just about any where.
Here is a good welding discussion board - not just about Hobart by any means! Use the search & ask your questions.
John
12-14-2003 16:09:31
 Re: Re: 110 volt MIG welders in reply to BobCaesar, 12-14-2003 10:37:28
I have a 110 volt craftsman, and it is excellent. i believe it is made by Century. it only cost $299. similar units from other companies cost $399. the difference is that the gas regulator on the craftman is non adjustable and has no gauges. for $100 savings i can live with that. the machine says it can weld up to 3/16 in one pass, but i have successfully welded 1/4 steel with no problems.
