Tool Talk Discussion Forum
Antique air compressor plumbing questions
Zira
12-14-2003 06:19:38
I have an OLD Brunner (sp?) air compressor (single stage, 2 tiny cylinders). The pump itself is mounted on a small cast tank, about 4" in diameter & 8" long. This tank is then mounted on a normal-sized (50 or 60 gallon) tank. I am not sure what the purpose is for the small cast tank, or how I plumb it in with the motor controls, etc.
I have a second old compressor (Champion) that appears to have had the air line go out of the pump, then through the crank-case of the compressor. Any ideas why it would be that way, or how to plumb in the controls?
Thanks for any help or suggestions.
I Like Case
12-17-2003 20:59:42
 Re: Antique air compressor plumbing questions in reply to Zira, 12-14-2003 06:19:38
It looks like you have stumped the forum:)
